Question about Electronics - Others
Do you have a wiring diagram for a Flo-master hp dual speed hot tub pump. 02115005-1. 1 had to buy a new pump. After the electrician has came for three weeks, and now putting me off for another week, and me attempting tonight there is no luck. I did find that there was no ground hooked up to the pump so I did fix that I cant get the house breaker to stop resetting. I also would need a thermostat diagram for an electronic timer for the hot tube. My boy tried to install a new one. its a German one i think, Liul. it has 4 prongs and i have 4 wires. on the timer box it has 123 no 4 then 56. I'm so confused. It worked well before this an now.. I employed an electrician and he charged me $100.00 to fix and that was 3 weeks ago. The hot tub is an Pacific Marquis
  • 1028 Answers
SOURCE: wiring a 3 prong neptune to a 4 prong new outlet
red and black wires go to outside screws ..white goes to middle screw..lift green ground wire from screw in cabinet back and either tape off or connect to middle screw on connector ..green wire on cord goes in it's place
Posted on Jul 30, 2008
  • 112 Answers
SOURCE: I need a wiring diagram for a Intermatic T104 40-amp timer
http://www.intermatic.com/images/instruction_sheets/T104.pdf
http://www.intermatic.com/Default.asp?action=cat&cid=91
if the 1st link doesn't work, use the 2nd and look for ur timer model there for the diagram.
if u need more help than this just ask
Tip: i usually use a photo cell in combination with the timer. i set the time for winter hours and let the photo cell take care of the rest.
Posted on Jan 11, 2009
  • 8 Answers
SOURCE: pool motor wiring
First and foremost, you need to check the Motor's voltage requirements, and match it to the voltage of the GFI you have connected to the House current.
The best way to do this is to use a volt meter at the GFI receptacle. Although it's likely the voltage at your GFI receptacle is 120Volts AC, you shouldn't guess on this. If you know what circuit breaker this GFI is using to get power.... you may be able to determine the GFI's voltage if you know how to distinquish between a single pole breaker and a two pole breaker (120Volts is derived from a sigle pole breaker, 240volts from a two pole breaker-which is twice the size of a single pole breaker).
Now the Motor: Most common Pool Motors are dual winding motors, on which, the voltage requirement could be changed to match the voltage supplied. On such a motor, there's a compartment where the cord is attached. Within this compartment, there's a configuration of screws or terminal points, and a related schematic which depicts the proper connections for each of the voltage options. By following these schematics, you will know how to connect the motor based on the available voltage supplied by your GFI protected receptacle.
Posted on Mar 23, 2009
tjt3
  • 44 Answers
SOURCE: gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Posted on Mar 24, 2009
  • 16 Answers
SOURCE: Dual Master Wiring
hzsupport.com shows the wiring diagram, the red wires go together.
Posted on Sep 27, 2009
Switching jets on trips RCD
This is usually an indicator that the high speed on your pump is bad.
Rod
US Parts Center
May 04, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
My hot tub is leaking from one of the pumps. how do i change the pump?
Sounds like you need a new Mechanical Seal for the wet end. Pretty simple job to change the seal kit.
It is also a lot cheaper to do that than purchase a new pump.
US Parts Center
Apr 19, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Aqua Flo Flo Master won't start on low speed
Water flow error on hot tub means low water flow. This is not enough water flow to turn the system on.
Some motors do have a start capacitor on them. you can certainly check that or take it to your local motor repair shop and they can check that for you.
Rod
US Parts Center
Jan 13, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
I was told that the Aqua Flo Master Xp2 Spa pump 1.5 hp 2 speed pump was the equivalent to the Sta rite Max E Pro 2 speed pump but then from another source was told that the Aqua Flo was not made for in...
I responded to the previous question in regards to the motor only. The xp2 does not have the strainer basket that the max-e-pro has . If this was a regular hot tub, the xp2 would work great, if this is above ground, then you do need a pump with a strainer basket. Again the xp2 will not work for an inground hot tub as the set up is different than an above ground unit.
Jan 12, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I took the pump out and repaced with a new one. The wiring lugs are different. the old one has White common, black low red High. The new one has no distinction as to what is low or high. How do I hook...
all US motors should have a wiring diagram on the side of the motor unit. The wires going into the pump would hold their same values. I am assuming the previous pump was two speed as well, if not that is your problem.
assuming that they are both two speed reference the common on the pumps motor diagram, and connect the white wire to that terminal.
reference the diagram for correct low speed and connect the black wire to that termial,
repeat for the high speed.
I deal alot with the flo master pumps and they should all be labeled. The most important thing is to get the common correct, switching the other two wires (black and red) incorrectly would simply result in high coming on when low is supposed to and vice versa.
If there really is not a diagram, here is the most typical setup for that motor.
(if you look closely at the terminals on the motor, there are numbers there)
connect the white common to terminal #5
connect the red hot wire to terminal #1
connect the black hot wire to terminal #2
connect the ground
done
Hope this helps.
If this post has helped you, please take the time to vote positively for me on this site.
thanks, and if you need more help, email me @ : adamh@newconceptchem.com
Oct 28, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Hot tub pump flo-master hp suddenly wont start. it' one year old and was working perfectly. air side started to make a squealing noise the night before. draining hot tub to check volute to make sure motor...
The fault is most likely to be the condensor. They can and do fail at an early age.
You don't need to dismantle the pump, on the rear of the pump you'll find a slot on the motor shaft which can be turned with a screwdriver.
If you've only just reffiled the hot tub it could also be an airlock.
Regards,
Ian.
http://hottub.synthasite.com
Apr 18, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Wiring diagram for flo-master 56 frame xp2. I have a new pump that was improperly wired from the factory.It is a two speed pump only running one speed. If I knew where the factory wiring should be...
The side of the motor will have a wiring diagram for how to connect the common, low and high speed leads. Your wire harness should have a white (common), black (usually low), red (usually high) and green (ground) wire. If high and low are backwards, switch the black and red leads.
Nov 23, 2009 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
I have a flo-master 06620390-2 pump that failed in my hot tub. Is there a quieter and more efficient replacement or should I replace with same?
You are generally better off replacing the pump with the same model. Hot tubs are noisy unless you have a really good insulation job. It is unlikely changing the pump will make it any different as far as noise goes. The flip side is that the manufacturer sized the pump to match the hydraulic load present within your specific tub and to provide the necessary flow rate to keep the water clean. It can lead to problems if you put in the wrong replacement unit.
If you would like a quote on the replacement motor and/or pump end, contact us thru www.arrowpools.net.
Sep 10, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Hot tub pump stops and control panel says there is a flo problem
Yes a pump does have a thermal cut out. When the motor gets too hot the thermal cut out will activate and the pump won't restart until the motor has cooled.
If you were an electrician, or highly confident/competent with electrics, you could test the motor with a volt meter. Run the spa and as soon as the pump stops running, check the voltage at the pump. If there is voltage at the pump, then the thermal cut out on the motor has activated. Do not try checking this yourself if you're not competent to do so.
You could also do the same test at the spa pack if it's easier to do so, just locate the output to the pump.
What spa and which spa pack have you got?
Cheers,
Ian.
Apr 24, 2017 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Electronics - Others Logo
59 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
