Question about Dell Inspiron 1720 PC Notebook
Inspiron 1720 reboots randomly. tried reseating ram and cant find solution. the reboot happens usually when i try to use programs and just shuts down and restarts like nothing happened. help is very appreciated.
  • camdamanjaco Sep 11, 2010
    i cannot find the auto restart turn off. no where in my startup will it say press F8. any other suggestions?
  • Dell Master
  • 629 Answers
Most likely related to the blue screen issues. a possible reinstall of the OS may be needed. To check if it is blue screen related, restart the computer, press F8 when system restarts, then select the option to disable auto-restart option on the advanced options menu and press Enter. Next time you use the system, see if it will still auto-restart or if you'll get a blue screen. If there is an error, a system rstore or OS repair or reinstall may also be needed.
Posted on Sep 11, 2010
  • 2 more comments
    thanks! will try turning the auto restart off.
    tried to get there but cant find where i push F8. any tips or other suggestions?
  • camdamanjaco Sep 12, 2010
    still stuck and now it wont shut down correctly.
  • Rodie Sep 16, 2010
    not sure if this has been sorted out, but press/tap F8 a few times while the computer is restarting. You will not see any message about it, just tap F8 a few times when the computer/Windows is restarting until yuo get to the Advanced Options menu
I have a dell mini 1020, i recently upgraded the ram and now it keeps shutting down and not restarting.
Have you tried to put yhe original Memory back in? Are the Modules seated properly? Are they the EXACT type? Unplug, remove battery, reseat or reinstall the originals, insert battery, plug in, reboot. NOTE: Be aware of ESD. Ground yourself.
Nov 25, 2012 | Dell Inspiron Mini 10 Notebook
Hi I have Dell inspiron 1720 (17 inches) laptop with intel centrino- window vista ultimate OS Problem: after system boots up, just before windows login, it comes "Please wait" and again it...
That's an interesting problem. It sounds like it's applying new display settings, but I'm not sure why it would do so over and over again. I would suggest trying to start Windows in "Safe Mode". To do that, as the computer is booting, hold down the F8 key to get the "Advanced Boot Options" menu. Maybe this will get you to a normal login screen. If so, you should try to change your display settings to the simplest possible and then reboot. I hope this helps.
Apr 10, 2011 | Dell Inspiron 1720 17" Widescreen...
My Inspiron 1 randomly shuts down in the middle of operations. In general, multiple internet pages are open as well as certain Office files. Have others seen this, could this be a function of over...
Yes, most likely. When a computer reboots randomly, it is usually some hardware malfunction, but when it shuts down completely, it is almost always heat-related. The CPU fan is usually the first place to look!
Mar 01, 2011 | Dell Inspiron One 2305 Desktop Computer...
Laptop randomly shuts down
Random shutdowns can be hardware or software related. General advice is as follows:
Go to support.dell.com and download the latest BIOS Flash, Video Driver and audio driver for your system and install them, once installed and rebooted see if the issue is resolved.
If not, start, run MSCONFIG, edit the entries in the startup group disabling all except antivirus entries, reboot and see if any change.
If issue no longer occurs, then you can add items back one at a time until you isolate items that cause the issue.
If the software editing has had no effect, try ram modules individually (System will operate on one) and see if issue is isolated to one module or slot.
Jan 15, 2011 | Dell Inspiron 1525 Notebook
Dell Inspiron 1420 shuts down instantly randomly. Then you have to reboot. Sometimes it does it repeatly others it doesnt. I have formatted and done a fresh install but the problem continues. I have also...
if you're not getting the blue screen of death it sounds like a hardware fault. If it's not too old contact dell. It could be something stupid like a duff battery connection
Oct 24, 2009 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
Inspiron 1000 green lights come on, no fans, blank dark screen, no cursor
Check your RAM chips. A bad RAM chip will cause this symptom. Could also be a bad MB. But check the RAM first since it's a much cheaper fix. Might also just need to be reseated. After reseating, pull the battery and power cord. Press the power button for about 10 seconds. Then reinstall battery and power cord and try to reboot. If symptom persists, it's likely the MB.
Sep 16, 2009 | Dell Inspiron 1000 Notebook
Dell Inspiron 1720 reboots while in use very frequently
Get it re formatted completely and doing a new partition.
Sep 12, 2009 | Dell Inspiron 1720 PC Notebook
CD/DVD drive no longer reading
go to your device manager and see if there is a problem there, go to:
start/control panel/device manager/cd,dvd then click on the + sign to open up your device. right mouse the device then click on properties, check to see if it is working properly and that it is enabled. then try to update the device driver
if you cant find a problem there scan it with driver detective at
www.drivershq.com
good luck, hope this fixes your problem
May 20, 2009 | Dell Inspiron 1720 17" Widescreen...
Keyboard failure on rebooting
reseat the keyboard connector to the pc or try another keyboard
Dec 16, 2008 | Dell Inspiron 530s Desktop Computer
Dell inspiron 1720 reboots randomly
there are several reasons why a pc restarts: 1. there might be a virus that causes this, thry to scan your computer using the updated anti virus. 2. your power supply might be faulty, if your pc frequently restarts the 12volts supply is having a problem, you need to replace the power supply. 3. operating system error, you need to repair your OS. what i have suspected from the problem you relayed is that your power supply, you need to replace this.
Apr 29, 2008 | Computers & Internet
Dell Inspiron 1720  PC Notebook Logo
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
