Question about Samsung SyncMaster 205BW LCD Monitor
Monitor is slow to come on. Have to press the monitor power button a few times before it actually comes on.
  • 11,361 Answers
Look for bad caps first in the power supply.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 12, 2010
Slow coming on. Blank screen until you press the on button a few times
guest, If you do not have any time to explore (investigate, read) then trade your old unit for new!! If that not option you wish to take , then read fixya monitor profiles of "louie12fix" , "budmrtn", "buddymc" and other tech's that specialize in repair of "cold-cathode-fluorescent-lamp back-lit lcd monitors. Follow all "links" you find in the profiles and view some video clips on YOUTUBE that deal with "lcd monitor disassembly" and "lcd monitor repair" to learn just WHY your unit acts the way it does. Why don't you try the "flashlight-test" that EVERY owner of an lcd monitor should know when a BLACK or BLANK screen shows up when it shouldn't be there in the first place. My best guess is that your monitor's problem is internal to unit and not a software problem. 12fixlouie Bye for now
May 19, 2010 | Gateway FPD1975W 19" LCD Monitor
Tip
Shut Down Your iPad For Real
When you press the power button on the <b>iPad</b> actually turns off just the monitor. That's why we talk so fast. What can be done to conserve battery power, or to recover from the freeze is to reboot the system. To do this simply by holding both the power button and the Home button until the red slider appears. Press and turn the <b>iPad</b>. Give it a minute and you can reboot by pressing the power button. It seems that a few seconds before responding so be patient.
on Dec 15, 2010 | Cell Phones
X193W LCD Monitor: screen goes black,if i press the on button a few t...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 17, 2010 | Acer X193W LCD Monitor
Power button is on (blue) but no display. If you
Try to change the screen resolution and frequency setting of your graphic card.
1. Restart your PC
2. Before getting into splash screen, press F8 frequently
Choose enable VGA mode by pressing up arrow and press Enter, wait until finish loading. Now the display looks bigger, change the screen resolution to best fit to your Monitor (normally 1360X800). DO NOT CLICK OK>go to advance tab> Monitor tab, choose 60Hz for screen refresh rate, NOW you may KLIK OK
Apr 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Slow flashing blue power lite. Monitor shows no
First when you power up the computer press F8 key then enter in enable vga mode.
If you are able to enter then go to start menu->control panel->display property ->settings.
Change screen resolution to 1024*768 then apply and ok.
But if you are not able to see safe mode and other menu.
Then open cpu cabinet .
Refix RAM memory.
Pull cmos cell from motherboard for 10 minutes.
Reattach all connection harddrive.
Open processor fan and processor remove dust from all parts.
Make sure motherboard is not ground with cabinet.
Remove PCI cards if any.
After all above still same then change RAM then try.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Gateway DX4640-UBC01A PC Desktop
Power light or screen will not come on my hp w2007 monitor. It's only 13 months old.
Possible answer as I had same issue. I found the button you press has small tip that presses the actual switch to turn the monitor on. My tip broke off so switch can not be made. Hp does not sell button as that is what I am looking for myself.
Dec 13, 2009 | HP W2007 LCD Monitor
Brightness pop-up window on screen for a long long time
There are a few things that could be wrong; someone could have a remote and be messing you about, a button could be stuck on the monitor so its increasing, the computer could be slow or signals might be getting mixed up. try and figure it out based on what ive said. good-luck!
May 20, 2009 | ViewSonic E70fb 17" CRT Monitor
Lg flatron w2234s monitor is flashing ??
I am going to suggest if it's only 3 months old you should take it back to where you bought it. Mine quit working right a few weeks after I bought it and they gave me a new one. Be sure you take your receipt with you. Even new things can mess up.
Mar 02, 2017 | Computers & Internet
Problem with 17" ViewSonic Monitor
The same problem w/ my viewsonic E70 17" monitor.The viewmeter or viewmatch color on screen do not appear when power ON, although the green led power is ON.
But if you rest your monitor for about 10 hrs or more the viewmeter will appear when you power ON the monitor.
You can now start your CPU.
Remember : No viewmeter screen on monitor when power ON, means no supply coming out the picture tube or high voltage.
But if there is Viewmeter on screen , this normal and OK>
Feb 04, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
TROUBLESHOOTING c-750
There are a couple issues related to "slow" that I have with my C-750, and this is how I get around them.
One is the write speed to the xD card. This can prevent you from taking sequential pictures quickly, as the camera displays the current picture it is writing until it finishes. You can make the image of the current picture go away and use your viewfinder again, while the camera is writing the picture, by pressing the shutter button halfway and releasing it. Then you can see your subject in the viewfinder again!
Second is the delay between the time the shutter button is pressed and the time the shutter actually opens (when the camera actually takes the picture). This can be fixed by lining up your shot and pressing the shutter button halfway and holding it for a few seconds. This will give the camera time to adjust and lock focus, shutter speed, etc. There is a small green dot on the display below the battery indicator which will blink a few times when the button is pressed halfway, then remain on steady. When the green dot is steady, the camera is ready. Press the shutter button, and the camera should immediately take the picture.
Nov 12, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Samsung SyncMaster 205BW LCD Monitor Logo
245 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
