Question about Car Audio & Video
I am trying to replace the antenna for my 95 civic cx hatch, but I am having a lot of difficulty feeding the wire through the A pillar. It is all just catching in a bunch and not coming out into the interior of the car. Furthermore, I can't fully remember where the hole was for the wire to come through.
There is a small grey or silver box with a plug in it. it has a 10mm bolt holding it in place. if you remove the box and wriggle under the dash you will find the opening for the wire. use a flexable wire such as a wirefish and thread it up to the top opening. this is a pain in the a** job; but can be done.
Posted on Jan 04, 2011
Need a wiring diagram for a 1986 honda civic 2 door hatch back .. specifically for for the steering colmn ..
Hi Google the following
1986 honda civic(type eng 4/6 cly whatever your is) 4 cyl.
click on images at the top and you will see lots to choose one from.
Hope this helps MIke
Feb 28, 2016 | Honda Cars & Trucks
Why a 1997 honda civic engine surges at idle
which engine, options there are many.???
cant fix any engine, until you know what it there.
a civic not Tacoma. as posted.
see end for engines ????
surge 101 (running gasoline?)
it caused by 2 things. (and lots of reasons)
1: engine running lean. all engines lean surge. fix that first.
hint use a scan tool see live data........?????
2: ISC system is faulting, the idle speed controller can fail for #1
or for itself. (it can stick) clean in.
wiki list of engines. (which one???????????????)_
The sixth generation featured engine options were available along with their first Natural Gas Powered Civic, the GX. From 1996-2000 the Civic was sold under the CX, DX, EX, EXR, HX, LX, and for Canada, SE, and Si trims; all base models were made with 1.6L engines. The EX-CX are all SOHC (Honda D engine). The CX, DX, and LX all have D16y7 non-VTEC engines; whereas the EX has a D16y8 VTEC, and the HX has D16y5 VTEC-E. The USDM Si and Canadian SiR came with a DOHC (B16A2 VTEC). The first civic SI coupe EM1 was introduced in 1999 until 2000. Europe saw a DOHC 1.6 VTI hatch and sedan and a DOHC 1.8VTI engine was available for the Domani related five-door liftback and esta
end quote.
I CAN NOT GUESS>!!!
Jul 01, 2014 | 1997 Toyota Tacoma
AIWA CX NA909 w/SXWNA 909 Speakers. Just hooked up for a friend that has been idle since a move 1 1/2 years ago. Can only get one FM station only. No AM at all...suggestions. Ralph
I guess you answered the question right then....., you need the antenna. If you've lost the antenna, I'd suggest a piece of wire, not too thick though...
As for the AM, that uses a loop antenna, so you might have difficulties with that one.
Oct 07, 2012 | Aiwa Audio Players & Recorders
What is the color code for wiring of 1999 honda civic
Honda Civic Stereo Information Constant 12V Blue/White Switched 12V Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Driver's Pillar Front Speakers 6 1/2" Doors Left Front ( ) Blue Left Front (-) Gray/Black Right Front ( ) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear ( ) Blue/Yellow Left Rear (-) Gray/White Right Rear ( ) Red/Yellow Right Rear (-) Brown/White
Mar 07, 2011 | 1999 Honda Civic
How do you change the atenna for a honda civic LX
Hi:
The antenna is held down on the roof by 2 or 3 screws, and the antenna wire runs down the inside of the driver's side of the windshield pillar and comes out down by the fusebox, approx by the drivers knee area. When I changed mine, I took the lower plastic from the bottom of the driver's side dash off, so I could see what I was doing. It was only a few screws to get it off. Once I had the antenna lead loose from the back of my radio deck, I tied a piece of string to the end, then taped it in place, then pulled the old antenna out of the roof, pulling the string up with it. I attached the string to my new antenna, and used the string to pull it back down thru the windshield pillar. Fasten down the screws, connect it back to your radio, and you are good to go!
Nov 02, 2009 | 1998 Honda Civic
Where can I get wiring diagram for 92 Honda Civic LX?
Here several documents:
Engine wiring-1992-95 Civic (except VX)
Engine wiring-1992-95 Civic VX
Chassis wiring-1992-95 Civic, 1993-95 del Sol
Good luck... remember rated this help.
Aug 19, 2009 | 1992 Honda Civic
I have a cold start starting problem with my 95 honda civic hatch
leave it to the specialists aye haha but if it was me id go for a dig i was just tryn to find a manual for my van to simplify the process
Jan 05, 2009 | 1995 Honda Civic
Door panel
Check the wires inside the rubber according between the drivers door and the pillar. you will find at least one wire broken. Grand Cherokees are notorious for this problem. At least it's easy to fix though.
Dec 30, 2008 | 2004 Jeep Grand Cherokee
Radio antenna
You should be able to take the plastic piece going down the inside panel from roof to dash. Usually somwhere in there or under the dash you will find a slip connection. But some go all the way to the radio.
Oct 09, 2008 | 1997 Honda Civic
Hatch back door on '95
yes, you can get a lock replacement for it, for a straight shoot, try getting it at the dealer as bad as this sounds.but will save you a lot of problems
May 20, 2008 | 1995 Volkswagen Golf
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
