Question about RCA Universal Remote Control
Looking for a code for my rcr6373/rcr6473 tv remote to program my toshiba tv
4 Suggested Answers
SOURCE: I dont have the codes to program my remote
i don't have the code book.can you email me the simplliest way too program this remote.
Posted on Nov 22, 2008
blueextc3221
  • 15935 Answers
SOURCE: LOOKING FOR THE INSTRUCTION MANUAL
Toshiba 000, 048, 049, 071, 072, 073, 105, 109, 117, 118, 160, 161, 162, 190, 201, 207, 283
Posted on Jan 08, 2009
  • 20 Answers
SOURCE: Need instruction and codes for RCA RCU3000WBL to prog. Toshiba TV
http://remotefinder.rca.com/default.aspx?site=rca
go here
Posted on Apr 14, 2009
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Dec 14, 2015 | Toshiba Televison & Video
What are the program codes for rcr6373r
Programming the RCA RCR6373 or RCR6373N Universal Remote Control Answer ID 11442 ' Published 09/21/2010 11:27 AM ' Updated 02/01/2013 03:00 PM How do I program my RCA RCR6373 or RCR6373N Universal Remote Control?
To use this universal remote with your home entertainment system, first you need to program it to control your devices. There are four ways you can program the universal remote to operate your devices:
  • The Auto Code Search goes automatically through all the codes for the device you're trying to control. It's the easiest method, but it can sometimes take longer than some of the other programming methods.
  • The Brand Code Search searches through the codes for select brands of devices. It's not as easy as the auto code search, but it can be faster.
  • The Direct Code Entry lets you enter a code from the accompanying code list for your brand of device. It's not as easy as the other methods, but it's potentially the fastest method.
  • The Manual Code Search lets you manually go through all the codes for the device you're trying to control.
Auto Code Search: The Auto Code Search goes automatically through all the codes for the device you're trying to control. When you find the one that operates your device, you can stop the search and store that code.
Tips:
  • Each device key is associated with a type of device- the TV is preset to search for TVs, SAT•CBL•DTC for satellite receivers, digital TV converters, or cable boxes, DVD for DVD players, and DVR•AUX1 for DVRs, AUDIO for audio receivers, and VCR•AUX2 for VCRs. To program a device key for a different type of device, see the Reassigning the DVR•AUX1 and VCR•AUX2 Keys section.
  • To control combo devices, like TV/DVDs and TV/VCRs, you need to program each key separately. Each key will control that part of the combo device.
  • If the original remote control that came with your device has separate ON and OFF keys (instead of a single POWER key), the Auto Code Search might not work with that device. Try the Direct Code Entry method described later in this manual.
  • To exit without saving a new code at any point in the Auto Code Search, press the CLEAR key.
  1. Manually turn on the device you want to control.
  2. Press and hold the device key you want to program. While you're holding down the device key, use your other hand to press and hold the remote's POWER key at the same time.
  3. Wait until the remote's indicator LED comes on and stays on. Then release both keys.
  4. Point the remote directly at the front panel of the device you want to control. Press PLAY on the remote and wait 5 seconds. The remote is testing a batch of 10 codes on your device.
    Did your device turn off?
    YES: Go to step 5.
    NO: Press PLAY again. The remote tests the next batch of 10 codes. Keep pressing PLAY every 5 seconds until your device turns off.
  5. When your device turns off, press the REVERSE key on the remote and wait at least 2 seconds. The remote tries the last of the previous ten codes.
    Did your device turn on?
    YES: Press the STOP key. You're done! You've programmed this device key.
    NO: Press REVERSE again. The remote tests the next code in the batch. Keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
Note: If you accidentally press the REVERSE key after your device turns on, press the FORWARD key. Then, wait two seconds to see if your device turns off again.
Notes:
  • Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the device you are currently programming the remote to control.
  • Test the remote with the device to make sure the device key is programmed with the correct code for maximum functionality. If some features don't work, try a different code. See the "Testing the Code for Maximum Functionality" section below for more information.
  • During the Auto Code Search, the remote ignores keypresses that aren't part of the search.
  • The search times out after two minutes (the LED blinks four times and turns off, and the last programmed code under that device key is retained).
  • The indicator light blinks four times and turns off when the remote has gone through all the codes. The remote exits the Auto Code Search. If your device hasn't turned off yet, try a different search method.
Testing the Code for Maximum Functionality:
  1. Try a variety of the device's functions with the remote. If some device features don't work, go to the next step to try a different code.
  2. Repeat the Auto Code Search Method from the beginning. When your device turns off, do not stop searching. Instead, with the unit now off, continue to press the PLAY key every 5 seconds until the unit turns back on.
  3. Once the unit turns back on, press the REVERSE key on the remote every 2 seconds until your device turns off again. When your device turns off again, press the STOP key.
  4. Test the key's functionality again by attempting to control a variety of the device's functions. If the code that has been stored controls the majority of the device's functions, programming is complete. If the code stored does not give maximum functionality, try another code.
Step By Step Videos
May 17, 2014 | Televison & Video
My remote for my RCA stb7766g1 was eaten by my dogs
has anyone found a remote that actually works with the STB7766, and if so, what is the brand and code?
May 08, 2010 | RCA Universal Remote Control
Remote codes for k2598u tv
Seeing that you haven't listed 'all' the codes that you have already used i decided to add these. Didn't know if it was 3 or 4 digit codes you needed so i posted them all. If there are codes in the 3 digit list that aren't in the 4 digit list just add a zero before the beginning and try them (that's if your using the four digit codes!)
eg. 3 digit code not on the 4 digit code list is 053 > then try 0053.
All the best,
Hughie. (codes below.)
4 digit.
0053
0011
0016
0047
0066
0103
0412
0413
0029
3 Digit codes
011,
016,
047,
053,
066,
157,
158,
176,
412,
413
Jun 19, 2009 | Konka K2568U 25" TV
Need programming methods and codes for sony tv
Have a look around in this site; http://remotes.com/store/codes_original.html let me know if it helps
May 11, 2009 | Televison & Video
Need code to program toshiba tv with Direct tv remote
I HAVE A TOSHIBA 32A33 TV AND JUST UPGRADED MY RECEIVERS AND REMOTES I CANNOT GET THE DIRECT TV UNIVERSAL REMOTE RC64 CODES THAT THEY HAVE PROVIDED TO WORK, ANY ADDITIONAL CODES ? PLEASE HELP
Dec 06, 2008 | Directv RC23 Remote Control
Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
Feb 05, 2008 | RCA DRD430RG DirecTV DTV Receiver
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Oct 01, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
283 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
