Televison & Video Logo
Posted on Sep 11, 2010
Keeps changing channels, push remote button and hold stays on that channel, resumes changing as soon as let go button
Anonymous
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Sep 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
6720
Points
71
It seems you have a problem with your remote control. Try using another remote with the same brand or you can use a universal remote control.
I don't know how to program my remote for my tv. It didn't come with a book.
remotes are all different give me the brand and model number but normally here is what you do
push setup> tv or dvd, cable whatever your trying to set up i wil assume tv.
hold setup until light blinks> release setup button and push t.v > from there use the channel up and down buttons to search for code > as soon as the channel changes hold down the mute button for a couple seconds and thats it. try to power on and off your tv
2helpful
Need intructions how to program remote control on vip722k second receiver
Press and hold down the SETUP button located on the remote. Wait until the INDICATOR light turns on. It will blink once the button is pushed, however once you see the indicator light stay one, release the button. Click the button to the DEVICE you wish to program. If it is a TV, then click the TV button. If it is the cable box, then click CBL button. After doing so, the indicator should still stay on. Press the DOWN CHANNEL button several times until you see the RECEIVER yo wish to program respond. Example: If it is a TV, then you will notice the CHANNEL change once the remote locates the correct settings for that receiver. If you see the receiver respond and you are pushing the down channel button but nothing is working, it means you passed the internal settings of the remote to the receiver. Try pushing the CHANNEL UP button slowly. It may be able to relocate the the proper settings. Once you see the channel change again, press ENTER to program the remote. If this fails, retry the same steps. In some cases you may miss the correct internal settings.
1helpful
Lost remote programing directions
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
NEED THE TV CODE TO PROGRAM A SANYO TV WITH A PHILLIPS UNIVERSAL CONTROL
try this:turn on the tv,now push and hold the code search button on the remote control until the led stays light release him push and release the tv button and the next step is push and release the channel up button until the tv changes the channel then stop and push the ok button to save the code.Good luck
2answers
Changing channels by itself
bought beko 32 wlu520hd when i change channel or volume the white indicator light on the tv flashes and starts going through all channels or volume just keeps going up .as if im holding down the buttons when im not , buttons on tv and remote do not respond. until i rub my finger over the senser on the tv, it stops but as soon as i press any button on the tv or remote it starts all over again .is this a fault in tv or is it static build up, does any one have the same problem , ive been on the beko web sight and cant find anything about this
78helpful
9answers
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
8helpful
Zenith zn110
1. hold in "code search" till light stays on
2. press channel up until tv changes channel
3. press enter as soon as channel changes
note: if you pass  the  right code just use channel down to get back to it
Can't change channels!!!!
take the batteries out of the remote...now check if you can change channels manually on the big screen. if so the remote is stuck on one signal that channel u said. get a new remote. if still same trouble on big screen look hard at the buttons and make sure none are jammed. also try to get to your setup menu and auto-program the channels it should search everything and then try changing channels. new stuff alot times plugs come loose, goes back to the factory workers...not pushing them tight have a tech check that at your home.
1helpful
2answers
After programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
