In the OPTIONS screen, click ADMINISTRATIVE, then INVENTORY MAINTENANCE. After looking up the item you wish to change, click the INSTANT PO button in the lower right corner. Enter a description such as "INV ADJ" and hit ENTER. Enter amount of adjustment, not amount in stock. If you need to deduct, enter amount of deduction followed by the minus sign (-) then ENTER. Your IN STOCK amount should update immediately. [email protected]
Feel free to email me with more details if need be.
to much air getting through
being careful not to over tighten or you will crack your inlet manifold
solution: tighten down your carburetor and tune up your carburetor
adjust the outside screw first that is your throttle screw
then once a full revs adjust the inside screw to where you want the max revs to be
If the magnet isn't close enough it won't know the wheel is turning. You don't needto ride it to see if it works. Just pick the wheel up off the ground and spin it. if it's working you'll see a speed. It's not rocket science but it also isn't magic.
you cannot adjust the seroentine belt, if it loose then you needto check your belt tensioner defects.
if it make noise then check the belt for glaze, replace belt
unplug the unit for more than an 1 hour then pung back in. this may help reset the magnetic motor. If not you need to replace batteries in the computer as well and let sit for hour before putting battiers back in. This may do it. If not you will needto have the magnetic motor replaced
sir im student i want billing and database tables for online sales and inventory for departmental stores kindly provide me er diag n class diagrams also as soon as possible
