Over filling washing machine. If you turn off power water still fills. Did another wash and it was ok but it has started over filling again. Also a slight buzzing noise fm washer
    President:
  • 3,773 Answers
This sounds like the water mixer valve needs to be replaced.
Its the part the fill hoses screw onto at the back of the washer
Unscrew the fill hoses at the back and run water in washer to verify the
water is there.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
Posted on Sep 11, 2010
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Washer start to run water the it just stop
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 20, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Washer stopped filling. power still on. turning dial to different positions has no effect.
water level sensor not working or load size selector switch failed. could also be a failed water inlet solenoid valve. Turn it to cold wash and see if water fills again, if not turn it to hot wash and see if it fills again.
Nov 21, 2009 | Maytag Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Water keeps draining from machine
Not sure what is occuring now. The machine is now working ok. I shook the machine up a bit & now its working, so who knows.
Mar 19, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer powers down during wash cycles
It is most likely a very slow fill problem ,either the cold or hot water supply is restricted and the machine cannot sense the right water temp. and will shut down .
Machine cannot wash properly with a small amount of water.
Ckeck ,the screens in the water valve or at the hoses at the top where the faucets are ,clean them or replace them but never leave them out .
Dec 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Model# 110 20902990 kenmore washing machine over flows
hi thanks for the question you could have a water valve problem how do you shut the water off by unplugging power cord or shutting off water supply if its unplugging the power cord you have a problem with water control switch or lint is caught in small plastic tube that goes to the water level switch check that could be no parts needed thanks the appliance doc
Sep 27, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Error code h20
hi sounds like a faulty fill valve easy fix
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
