GE Energy Star WCVH6260F Front Load Washer Logo
Posted on Sep 11, 2010
Anytime this machine goes into a spin cycle it is grossly out of balance. we have tried adjusting the load; reducing the size of the load; we have gone to just one towel in the washer and still out of balance to where the machine is still bouncing around. we have a load of towels that are still soaking wet after the cycle.
Smitty
Level 1:
Champion:
  • Contributor 240 Answers
  • Posted on Sep 11, 2010
Smitty
Contributor
Level 1:
Champion:
Answers
240
Questions
0
Helped
66195
Points
50
Are the locking nuts tight on all 4 legs? If not, tighten all locking nuts after leveling machine. Also, place a glass of water about 18" in front of machine while spinning and see if water moves. If it does, you may have flooring issues.
Intermittent no spin
What is the complete model number of your unit?
Samsung WF231ANW VRT Loud and aggressive spinning, banging against the wall
You have to make sure the load size is the exact match to what size your load is.
2answers
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
2helpful
What does UE fault mean? & what do I have to do?
UE means the washer has experienced a severe out of balance condition during the spin cycle, do not overload the washer and if necessary reduce the wash load size, distribute the items in the washer more evenly, this is especially true with heavy items like towels and jeans,.
Washing machine shuts off before cycle is finished now it will not last one min. on before it shuts off...what to do?
We have a front-loading LG washer. Today, I took a look at it when it was beginning the spin cycle because it sounded a bit different. I noticed that it was beginning to spin and would stop because [I believe] it was detecting a strong off-balance. It would then try to spin in the opposite direction and the same happened. After two more attempts, it automatically shut off with no warning nor error. We set the washer to wash and spin again and I began to work on balancing it. After adjusting the feet and waiting for the spin cycle again, it continued successfully because of the reduced off-balance. I'm not sure if there are other reasons that would cause the washer to turn off. This is the only one I have come across so far.
1helpful
Machine drum makes loud noice in the spin cycle. Makes the same sound that a top-loading machine makes when it goes out of balance. Help.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
3helpful
1helpful
Off balance
make sure you have all the shipping material out of unit..4 bolts in back and styrofoam under tub if so ,then get a adjustable wrench ,,,put unit in drain spin cycle or spin cycle only..when unit gets to fastest spin ,,thats will come when its about 8 minutes left..tighten each leg lock nut on unit until unit stops vibrating..only turn the lock nut not the leg..only adjust lock nut on legs in high speed spin
Balancing
This type of thing should not be required. Front load washing machines (well, topload too i guess) will balance themselves out for the spin cycle unless the machine is grossly overloaded.
Good luck.
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
