I have 5 philips cs3450 e speakers I want to hook up to a pwr2006-37 subwoofer, but it seems the previous owner cut off the adapter plugs off the speakers to hook up to another system. So my question is where can I get replacement adapter plugs so I can still use this subwoofer with these speakers?
zaids
  • 456 Answers
SOURCE: Denon AVR-487 SYS-57HT SPEAKER SYSTEM
check that wire and fuse again and try to reset and try
Posted on Dec 11, 2007
robotek
  • 1512 Answers
SOURCE: subwoofer hookup
Hi silverfox55
You probably wont experience any sound quality losses, however, you may pick up mains hum that will be noticeable at low levels, and also prevent you sub from auto turning off. It will also be suseptible to RF interference, such as that from taxi and police radios,and mobile phones. Try it first, you may find that it works ok. Your house may have foil building paper as insulation that will sheild the outside sources of Rf interference. The mobile phones however... If it doesnt work, I suggest you use the existing speaker cable to pull through for a run of decent audio coax. This way you will not end up with any unwanted signal getting into your sub.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 03, 2008
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Posted on Jun 24, 2008
acdr
  • 1913 Answers
SOURCE: I want to get full surround sound out of my Denon AVR-1508 w/sub
reset all settings to factory defaults.also check all connection is properly connected.but u have to reset all settings bcuse settings are conflicted.
Posted on Jan 18, 2009
SOURCE: KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Had the same problem with KLH E-10D Preamped Subwoofer. Afte brief research, I found the problem was with my Pioneer VSX-D509S reciever settings, not the subwoofer. If you have the same reciever, you can go to the pioneer website to download specific model owner's manuals.
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/ch.AV-Receivers.Archived?vgnextfmt=Archived
Select your Pioneer reciever model and it will give you an option to download the pdf manual. Hope this helps.
Posted on Jan 24, 2009
How to hook my factory amp and subwoofer from my Cadillac into my 2000 Chevy silverado with an aftermarket DVD/cd player
if you cut out the factory plug to amp look in owners manual for caddy to see what wire is what or research it on web best advice i can give you
Mar 05, 2013 | Car Audio & Video
I need pinout assignments for a Philips 5.1 Home Theater Speaker system (PWR2006-37)? It has a DB-15 style input connector that hooks to the output of a Philips dvd / amp / control unit. this was...
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
Jul 10, 2010 | Philips DVP642 DVD Player
How do i take out the factory stereo for a 2008 mazda 6, in order to install an after market amp?
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/pdfs/receiver_guide.pdf
Hi Lo Adapters
Hi/Low adapters are devices that installers use to convert a speaker level stereo to RCA levels so it can be hooked to an external car stereo amplifier. You can cut the speaker wires and hook the hi/lo adapter right up or you can tap onto existing speaker wires without cutting them so the speakers still play while the tap gives you a connection to the hi/lo device for adding something like a subwoofer amp to the existing speakers.... We have hi lo converters in TWO CHANNEL and FOUR CHANNEL configurations and we have them WITH and WITHOUT adjustments.. The adjustable hi/lo converters allow you to fine tune the hi/lo device to match other levels in the car or to make sure the match between your stereo and amplifier is a good match.. The adjustable line converters are the most popular.. We also have some specialty hi lo converters that have special radio plugs on them that may plug right into your factory stereo.
Now you can install an amplifier with your factory radio or install a new radio with your factory amplifier!
Mar 30, 2010 | Kenwood Car Audio & Video
How do i hook up two altec lansing speakers and
Depending on the sound card installed in your system, integrated into the motherboard or not, you may need a "Y" splitter adapter. Typically, the subwoofer has a black plug while the regular speakers have a green plug. The red color is a new one on me, but let's assume that it is the subwoofer. If you have a black outlet on your computer, plug the red one into that outlet.
If your speakers came with your system, HP would have provided you with proper adapters to make the speakers work for whichever speaker system you have. If you have any "Y" adapters, use them.
Feb 23, 2010 | HP Pavilion a1610n PC Desktop
I have a BMW 318i 1993 and when i got it there was a big speaker and amp hooked up. I unhooked it but now i cant get any sound....the radio lites up but no sound. i know speakers work cuz they worked...
Hello pinkpimpin20,
Without knowing exactly what modifications were made to the factory sound system, it's difficult to point you to a particular fix. The number of channels on the "big amp" that you disconnected would help. Even the make and model.
But, from your description it's possible that the previous owner installed a multichannel amp to drive both the "extra bass speaker", usually referred to as a subwoofer, and the original vehicle speakers. In that case, the speaker wiring from the head unit (receiver) was cut and the receiver side of the wires was rerouted to the input of the aftermarket amp. The output of the amp was then connected to the other ends of the speaker wiring.
To restore to the original, you need to pull the stock receiver and resplice the wiring. If the previous owner cut the plug completely, it may be necessary to purchase a replacement from your BMW dealers service or parts department. It's possible, but not likely that the previous owner used both an aftermarket "harness" and an aftermarket "reverse harness" to avoid having to cut the wiring. In that case, all you'd have to do would be remove them and plug the radio harness back into the vehicle harness (or the back of the radio). But most DIY audio enthusists don't mind butchering the vehicle wiring. And you'll probably find that electrical tape was used to secure the wiring. After a year or so under the dash, it'll be a sticky mess to unravel.
The speaker wiring colors for the '93 318i are as follows:
Left Front Speaker Wire (+): Yellow/Red
Left Front Speaker Wire (-): Brown/Orange
Right Front Speaker Wire (+): Black/Red
Right Front Speaker Wire (-): Brown/Orange
Left Rear Speaker Wire (+): Yellow/Black
Left Rear Speaker Wire (-): Black/Orange
Right Rear Speaker Wire (+): Blue/Black
Right Rear Speaker Wire (-): Brown/Orange
Hope this helps.
Sep 24, 2009 | Jensen Car Audio & Video
Bass not plaing only the small speakers, do i have it hooked up right?
I'm having the same problem, bass will cut out randomly everything is plugged in correctly if you bump the subwoofer it seems to come back on for a bit then back off, did you ever find a solution for this?
May 23, 2009 | Logitech Z-560 Computer Speakers
Subwoofer with speaker wire?
Back in the old days, subwoofers were powered by the voltage from your receiver, through speaker wire.
Nowadays, subwoofers have their own power, hence not having speaker wire connections anymore.
It's unlikely that you'll be able to connect your old subwoofer to your new receiver.
You'd need to get a new one, which if you don't mind buying closeout, can be found on eBay pretty cheap.
Mar 16, 2009 | Sony DAV-DX255 System
I have recently purchased an rx8, but the previous owner had fitted an after market stereo which he took with him. I have 2 problems, i have purchased a double din system which i tried to fit. I was able...
If the unit was installed professionally no wire's will have been cut from factory harness. Yes you would need an aftermarket adapting harness so your speakers will work . Vehicle may also be equipped with a stock amp. be sure to hook remote wire on harness to head unit.
Dec 03, 2008 | Car Audio & Video
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    102 people viewed this question
     Grubhead
    Grubhead
