Question about LG LRSC26944 Side by Side Refrigerator
Main Control Board Failed - LG LRSC26944 Side by Side Refrigerator
  • LG Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 11, 2010
Why doesn't dispenser control board work?
the main board could have failed and also caused the dispenser board to not work. What is the model number of the refrigerator?
APPLIANCE 911
Jan 21, 2016 | Refrigerators
What does F06 mean?
F06 error code indicates a motor tachometer failure on most Kenmore Elite front load washers. There are many different models, so I would need the model number of your washer to be sure.
This type of problem could be caused by loose wiring connections between the motor and the motor control board. It could also be caused by loose wiring connections between the motor control board and the main machine control board. Other problems that could cause this fault code include:
A failed drive motor.
A defective motor control board.
A failed main machine control board.
Hope thie helps (remember to rate and comment this answer)
Jul 02, 2011 | Kenmore Elite 45986 Front Load Washer
What does F1 mean for a whirlpool cabrio
F1 error code is for main board failure, replace main board
Sep 07, 2010 | Washing Machines
My washing machine now reads lr and wont spin or wash
The lr fault code simply means Locked Rotor.This indicates that the main motor is not being detected as running by the control board in the console.This could be a wiring problem between the motor control board in the right hand base area and the main control board up top.Itmost likely is a failed motor control board or drive motor.
Aug 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a Kenmore Double Oven that's eiving a Code 7 and beeping
Hello,this code is the result of a failed function key on the key pad, or control board. Some control boards will have the touch pad, or key pad combined with the actual control board, as one whole unit. If this is the case, simply have the main control board replaced. Now, if the touch/key pad is separate from the main control board, this will require you to gain access to the control board and key pad, and preform this test below to isolate the failed component.
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks
Jun 02, 2010 | Kenmore 43389 Electric Double Oven
Kenmore model 911 4238816 - the f7 code just came on beeping and we can't get it to stop. what is the error code mean, what can we do to stop it
HI. This code is the result of a failed function key on the key pad, or control board. Some control boards will have the touch pad, or key pad combined with the actual control board, as one whole unit. If this is the case, simply have the main control board replaced. Now, if the touch/key pad is separate from the main control board, this will require you to gain access to the control board and key pad, and preform this test below to isolate the failed component.
Jan 03, 2010 | Kenmore Ovens
Oven blinking code F7?
Determine if problem is with the Key Panel or Control by:
Dec 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Clicking noise in the circuit board and everything in the freezer is thawed
Hi. this will be a failed relay on that circuit board. This is called the PCB(main unit power control board). This board controls the compressor relay functions, and the compressor power current, as well. The evaporator fan, and condenser fan, receives their respective current from this power control board, also. When a circuit board of this nature begins to malfunction, it will cause the unit to not cool properly, due to limited, or no fan actions, or a failed compressor cycle. I would recommend to replace this damaged control board, asap.
Dec 04, 2009 | GE Freezers
My washer has a f1 code will not spin or wash
OK, your unit is quite unique. this unit has a integrated control design that houses the main and motor control board. both are combined on the same board. this error code represents a failed Machine and motor control board. this single control board works as the main controller and, as the motor controller as well. This board has failed in your unit and, you will need to replace this board asap if possible.
May 30, 2009 | Whirlpool WTW6400SW Cabrio Washer
LG LRSC26944 Side by Side Refrigerator Logo
78 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
