Water builds up at bottom of unit and begins to drain out of the bottom left corner.
  • 144 Answers
Is it level water will go to lowest point is the outlet of drian clogged level and pour water in it to see if it will drain properly
Posted on Sep 12, 2010
We have a Kenmore Elite 795 fridge. It is constantly leaking water from the bottom right corner of the unit onto the floor. There always seems to be a build up of ice at the bottom of the unit.
Usually the result of CONDENSATION due to eithr bad door seals allowing air and moister in to condensate. or a plugged or clogged evaporator drain line which causes water to back up and freeze or leak out the lowest point the bottom?
Mar 19, 2015 | Kenmore Refrigerators
Water is draining into the house?.where is the drain?
Hello, the unit must be tilted back in the window to prevent the condensate from leaking inside. Some units will have a drain plug on the bottum, while others use the condenser fan to scoop up the condensate and splash the condenser to keep it cooler and evaporate the condensate.
May 29, 2012 | Maytag M3X05F2D Air Conditioner
When the cycle finishes, there is water in the bottom of the dishwasher this begins to smell
there is some kind of clog in the drain system. clean the screen in the dishwasher, there gets a build up of food, or misc stuff in there. it is probably draining, but slowly.
the dishwasher usually has a pump that pumps the water out with force, but if clogged it will be slowed down and when the cycle stops there will be water left in bottom
hope this helps
rick
Jul 15, 2011 | Dishwashers
Drainage on this older system. Even at a slighty titled angle i am still having water run off inside the house. Couldn't find a weep hole either. What to do?
John, in addition to tilting the back of the unit 1/4" down, check the drain pan hole for a clog. This would cause the pan not to drain as it should.You may not see the weep hole it's clogged. It would just blend right in.
Jul 05, 2011 | Heating & Cooling
Model A3006F2D. doesn't seem to be draining. is there a drain hole?
N0 there is not drain hole. Newer A/C units throw the condensation water up to the hot condenser coils outside to help cool down the coils.
Jun 21, 2011 | Fedders Heating & Cooling
There is water in the living room floor after the unit runs even for a short time. Where do you locate the stopped up drain. Where would I begin my search?
If your furnace is in the closet or laundry room, the coil that's leaking is either(1) on the top of the furnace if your ductwork is in the ceiling,(2) on the bottom of the furnace if your ductwork is in the floor. The drain that may be stopped up stubs out of the bottom left or right hand corner of the coil box. Sometimes you can flush it out with water but the best way is to find the end of the drain and get a shop vac and stick the shop vac hose on the drain, seal it real good and try pulling the junk out of your drain. Your drain may drain outside somewhere on maybe to a floor drain.
Apr 12, 2011 | Heating & Cooling
Ice build up on bottom freezer
Ice build up on the freezer floor alone, with no ice on shelves or food above the floor, usually indicates a clogged defrost drain problem. when your unit goes into defrost, the melt water is intended to go down a drain tube from the freezer to a pan on the outside bottom of the unit, usually near the compressor. Sometimes these drains are clogged with food debris, other times some of the melt water does not completely drain, and freezes - this build up of ice can then clog the drain. You can unplug the fridge, with both doors open and a fan blowing for 24 hours to temporarily remove the ice and water, but it will return most likely, in which case you would need to have the drain cleared out and / or have a drain heater installed by a qualified refrigerator repair service.
Apr 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
AC is spitting out water inside. Where are the drain plugs?
I have the same AC and had this problem. Sludge builds up inside the bottom of the unit from dust and water build up causing it not to drain and the fan spits the water out. Its a fairly simple fix with a philips screw driver and a wet vac. Unplug the AC first. Remove the AC from the window. Remove the screw inside the front panel below the filter screen. Then you can pop the whole front panel off by pulling it with a little pressure. Now you need to remove the 3 screws holding each of the slider panels onto the side of the AC. Then remove the 3 screws on the bottom of the left and bottom of the right side of the AC. Remove the 3 screws holding the bar on top of the AC. Lastly remove the 2 screws on the back of the AC in the bottom Left and Right corners. You can now pull the top cover off. You can now use your wet vac to vacuum out the sludge that is in the bottom of the AC from the right and left side. There's a ground wire that connects from the fan motor to the bottom plate of the AC, be careful not to hit it. I knocked mine off possibly to it having been rusting in the backed up sludge and had to strip the wire and reconnect it.
Jun 02, 2009 | Heating & Cooling
Refrigerator leaks water
most likely you have a plugged drain int he freezer compartment. if yo will look under and behind the lower basket in your freezer you will most likely see a bunch of ice build up. clear this ice out then you will see a drain hole in the center section behind the metal cover in the rear try to get some hot water into this hole to clear ice and to clear the drain then u shoul be good to go. thanks for using Fix Ya Peyton
Feb 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice at the bottom of the freezer
bottom of rezzer compartment is supposed to be frozen( depending on timeof cycle) i wouldnt point to a defrost problem unitil the ice build up is hindering refigeration, its quite possible that thte defrost drain has just frozen itself over, and needs to be cleared to allow defrost water to go into the drip pan under unit
May 02, 2008 | Maytag MSD2756GES Side by Side...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
