Question about HP OfficeJet Pro K8600 Printer
New printer. HARDLY USED Worked fine when first installed. . Now shows as offline on all five network printers. Ethernet connection. Power is on. Tried rebooting, Checked connections. Is the printer faulty? What to do nect?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
1. Try to print from local system if it does not then reinstall printer driver. check catridges.
2. Now right click on the printer using sharing options, share it again.
3. On the other computers using network icon, browse the printer connected system. Explore the system till you see the shared printer and double click it. It will take 2 to 5 Minutes and then your printer is network connected.
4. Now remove the old printer icons. And check printing using the new one.
Posted on Sep 11, 2010
Idle printer status
If your computer is USB connected make sure that the cable is connected and that the printer is powered up. If you are connected to the printer over your network through wifi or ethernet, make sure that each device (computer and printer) is connected.
If all of these are in order and the printer still shows offline, try re-installing the software that came with the printer. Sometimes the software needs to be re-installed due to corrupted files.
Nov 24, 2013 | HP Computers & Internet
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
I have A Canon MX410 printer and is showing message offline and I have unplugged and plugged the printer. I have a Mac Mini and it worked fine for awhile. What to do??? Thanks Rick
Is the Pixma connected to a wireless router (or connected by USB or ethernet cable)? It could be that the router connection failed. Try restarting the router, or repeat wireless connection on the Pixma.
Feb 04, 2018 | Canon Pixma MX410 All-In-One Printer
X75 My color won't work. Black is fine. I installed a new one at Xmas and it worked fine. I hardly printed anything.. Yesterday the test page with peacock showed no blue and everything came out yellow. ...
run the print head cleaner tool using the lexmark software. since you hardly used the color the print head nozzle is dried up and needs to be clean.
run the print head cleaner atleast 5-10 or more times as needed.
Mar 12, 2011 | Lexmark X75 All-In-One InkJet Printer
Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
Sep 13, 2009 | Brother MFC 490cw Color Inkjet...
Hp 6310 show offline wont print
Hi, how do you connect to the printer? USB/parallel/Network? Does it prints fine if you print an information page from the printer display/butons? I would try to uninstall the printer driver and install it again to start. It's definately a communication problem so it may take a few tries to get it to work again.
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
Printer is offline
go in control pannel> printer> right click on your printer there was option use printer online click on it
Jan 17, 2009 | HP Deskjet 3915 InkJet Printer
The 8860 printer is showing offline on the network
sounds like you need to open the sharing section of the printer set up, and set it for sharing on the network
Jun 16, 2008 | Brother MFC-8860DN All-In-One Laser...
Wireless and wired connection fails with Toshiba laptop
Do you have a firewall turned on that might be preventing your computer from communicating with the printer properly?
Jun 27, 2007 | Canon PIXMA iP5200R InkJet Photo Printer
HP OfficeJet Pro K8600 Printer Logo
123 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
