Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
2001fp the screen is black the power light is green. It will flash when first turned on but wont light up. I have it apart and I don't see any obvious bad caps
  • 11,361 Answers
The problem can be in the inverter board: http://www.lcdrepair.us/2001FP-INVERTER.html
You can try replacing the inverter and hope that the problem is not in the backlight assemblies. You need the test lamps to verify the function of the inverter board. Do you get steady 20vdc feeding the inverter. You can also try heating up the two black electrolytic caps on the inverter board to see if the inverter will fire up using hair dryer, when bad caps with high ESR are heat up the ESR will go down.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Posted on Sep 12, 2010
  • 2 more comments
  • mtnman47m Sep 12, 2010
    This is the inverter board that mine has. Do ya think those caps may be bad? they are not swelled up that i noticed.
    http://www.lcdrepair.us/2001FP-INVERTER2...
    Also I have 2 of these monitors with the exact same symtoms. I bought them from an auction allong with 4 1905fp monitors. The 1905fps' had 3 bad caps on the power supply board that were obviously swelled on the tops, quick easy cheap fix. All 4 had the exact same problem. I am in no way an electronics engineer and do not know how to actually test caps or any other componants, if they are not obviously bad, looking at them. I appreciate your feed back on this, its nice to know that there are people in this world that don't charge for shareing knowledge.
    UPDATE........DAAA make sure the power supply is adiquate. I just checked power supply out put it was only 12vdc requires 20vdc @ 4.9amps. works great with enough power (both of them) Thanks any way for the info.
  • Bud Martin
    Bud Martin Sep 12, 2010
    Glad you check the power supply voltage, 12v dc is fora 17" and smaller CLD backlight screen, 16~20vdc usually for 19~22" screen.
    Bad cap can look nprmal but can have high ESR, it takes only a few Ohms of ESR for the circuits not to work even though the cap value still read out OK.
    See exampe here:http://s807.photobucket.com/albums/yy352... FPD1830/
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Dell UltraSharp 2001FP (Gray) 20.1" LCD Monitor
Most likely, this is failing "inverter."
The backlight of the monitor (that makes the image visible) is controller by a special chunk of electronics called an inverter. They tend to fail over time. The symptom is that the backlight either never comes on, flickers, or shuts off after a short period of time.
It is a moderately advanced repair job to change out the inverter, but you can usually get the part on eBay. Search for the exact monitor model number and "inverter".
The 2001FP has six lamps and the inverter is fairly expensive. You might be better off putting that money towards a newer monitor.
Apr 11, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Dell Monitor 2001FP Blank Screen
From your description your backlight is going out. The fluorescent light when it begins to burn out tries to draw too much power. Your inverter is sensing this 'too much' power draw and shuts down power to the back light. Replacing the backlight is the most technically difficult repair of an LCD, and most repair shops don't even offer this service. I recommend that you sell your LCD 'AS IS' on eBay or a similar website. The Power board and the Control Board are both usable parts that can be easily salvaged from most Dell Ultrasharp monitors.
Oct 05, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Monitor wont turn on, green power light on
Hi you can inspect that what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
Dell 1901FP monitor
It is probably either a CCFL back light issue inside the LCD or a set of capacitors on the inverter/power supply board.
Would you be willing to part with it ?
Oct 26, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Monitor has no power or wont turn on
Gumpster, Yes, there are replaceable parts inside, however, the question is can it be fixed economically. If this was supposed to be working I would return it as fast as you can. If not then it could be your logic board ($80 approx) or your external power supply ($25 approx). If you decide to pursue this take proper precautions to protect yourself and the monitor components. Let us know how things go and please don?t forget to rate this post.
Feb 25, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
1,254 people viewed this question
Alun Cox
