Sound goes off and on. While playing music sound goes off for about 5 seconds and the comes back. Same thing happens when view videos on the internet.
    Problem Solver:
  • 5 Answers
Is u cable connection of speakers ok/if yes than it seems to be a sound card driver problem/better install ur sound driver again by complete uninstalling previous one/ if u don't have driver then download form ur pc manufacturer website/or search on google
Posted on Sep 11, 2010
ONKYO Tx SR608 GOES TO "NO SIGNAL" WHEN PLAYING MUSIC DVDs. Not in movies though
that sounds strange. your receiver is not that smart to work out the differences between movie and music dvd. more info would be good.
Apr 09, 2014 | Onkyo Audio Players & Recorders
Onkyo tx-ds989 goes to stand by mode just playing for 3 second ... rest every thing is ok I just hear a click sound (relay switch off) and it goes to stand by mode again switch it on .... same thing...
Check the speaker wiring on back that it is not shorting against one another, output ic's may have bad solder connections and should be checked carefully.
May 28, 2012 | Onkyo Audio Players & Recorders
Sound dies off gradually for a second or two, then comes back. This happens often. Thanks.
It sounds like there is a thermal problem. If you can't make it happen by shaking, or banging on the amp. If it comes and goes with the shaking and banging then there is some loose connection.
If you still have trouble we here at Pro Line Music have a service department and can repair it.
2157368055
May 27, 2011 | Behringer ACX450 Ultracoustic 45 Watt...
Sound on my pc goes in and out randomly..
Are you sure it's the pc? I assume you at least have some powered speakers if you play music through the pc consistantly. Could be shorting out. Could be many things really. I'd try different speakers 1st and if the same happens then it's pc. From there I'd focus on the power supply. Could be shorting or on last leg. If this only happens after a long time of playing then could be the pc is getting overheated. Hard to say without knowing the quality and condition of pc and parts. Could be the electrical outlet it's plugged into. Move pc to another location and if knowledgeable enough make sure it's plugged into a totally different circuit. As crazy as it sounds, I've tested pc's running off a vehicle inverter from batteries which can actually run better more consistant power than the power company. Beyond heat and electrical, and if not the problem, then I would assume you are trying to do too many things on the pc and bogging it down and using a single core with low amount of ram.
Sep 11, 2009 | Mach Speed P4MBMS Motherboard
Videos only play for 8 seconds (Sansa View 8gb)
it needs mp4. the website you may be getting it from might be invalid.
Dec 26, 2008 | SanDisk Sansa e250 MP3 Player
Crackling Audio
Is there any other programs running in the background IE Anti-Virus programs, or anything that could be using quite alot of Memory other the stuff your watching?
It could be either down to Lack of Memory being allocated to the Audio & Video (Probably the case if the machine has built in Shared Sound & Video Card). Try opening Task Manager and setting the Application that you use to play Music/Movies to High Priority.
If it's not that try lowering the Master Volume on the Mixer Device by going into the Volume Properties in the Task Tray (By the Clock).
Dec 04, 2008 | HP Compaq Presario V2000 Notebook
Sanyo Television PLV-55WHD1
i heard same popping sound and my power button flashed red and will not turn back on.?
Sep 15, 2008 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
2002 Ram Radio problem
It sounds like a cold soldered joint internally in the radio. My advice is to buy a nice aftermarket radio with an MP3 CD player. MP3 gives you the option to burn music from your computer. In addition, MP3 CDs will hold over 100 songs per CD.
It MIGHT be a poor connection at the power connector on the rear of the radio. You could try pulling out the radio and cleaning the connection before purchasing a new radio.
Aug 08, 2008 | 2002 Dodge Ram Maxi
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sherwood Amplfier
Sounds like you like your music like me... LOUD. If you've done this a number of times, there are a few things that can happen:
1. You've blown the speakers... but you've said it operates for 2 seconds, then cuts out.
2. You've damaged the amplifier modules within the amp and they immediately overheat upon power-up. Does the music come back like 5 or 10 seconds after the unit cuts out?
3. Thermal switch has malfunctioned and just cuts off the power to the amplifier modules as soon as it sees any heat.
4. If you've gotten the amp really HOT during playing, it's possible that it's as simple as the amp modules are only intermittently connected (fatigued/stressed or cold solder joints) at the on the PCB. Just resolder the connections of the amp module to the PCB. I've seen that happen numerous times and that's where I'd place my money.
Jan 02, 2008 | Audio Players & Recorders
Computers & Internet Logo
David Payne
David Payne
