Question about Kenmore 30169 Electric Single Oven
F 7 ERROR KENMORE OVEN MODEL 911.47169791 - Kenmore 30169 Electric Single Oven
  • 15,935 Answers
The F7 error code indicates that one or more potentiometers (burner switches) are not connected properly or that you have one or more failed potentiometers.
The specific details of this failure code are provided in the second image below.
This is an excerpt from the technical information for this range.
Normally, a service technician would be needed to conduct the troubleshooting and diagnosis for this type of failure.
If you are completely confident in your technical ability to safely unplug the range and access these potentiometers (54 in the third image example) you may be able to check for loose or broken wires that could be causing this code.
If no loose wires are found, then you will likely need to have a technician find and replace a failed potentiometer.
IMAGE1: http://media.fotki.com/1_p,wfdddkwdfrwkdtqxgtqsskgwtqkq,vi/gfwdtqtbrxgdkgqwqtb/1/1303472/5961857/image11662img-or.gif
IMAGE2: http://media.fotki.com/1_p,wfdddbrbbbbgfttxgtqsskgwtqkq,vi/gsfkbbsqqxgdtwdgbsg/1/1303472/5961857/image11663img-or.gif
IMAGE3: http://media.fotki.com/1_p,wfddfqsqwsbqtrwxgtqsskgwtqkq,vi/gtfggdrdwxgftrgbbtf/1/1303472/5961857/image11664img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
Kenmore stove the oven wont come on it says dr
The DR error can mean that the door lock is enabled (or the oven believes it is). If the oven door was open and the Clean button was pressed, this can happen. Try pressing Cancel with the door closed. If the door is open, press the oven light button in and press Cancel. Try unplugging the oven (or flipping the circuit breaker to off) for a few minutes to reset the error.
If these don't help and the oven is not locked, then the control unit probably needs to be replaced. If you add a comment with the model of the oven, I may be able to direct you to the parts.
If your oven is still under warranty, contact Kenmore. I hope this helps.
Jul 03, 2014 | Kenmore Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Error message f4 fan lt electric double oven model 49425 & 49429
Every fault code I am able to find concerning F-4 period has to do with bad oven sensor. This is the probe coming through the wall inside the oven to read oven temp and to regulate it. Hope this helps. Rick
Mar 04, 2010 | Ovens
E1-F1 error on Kenmore Range
A persistant F1 error code usually means that the oven has exceeded the safe maximum operating temperature for the oven.
This is usually due to a faulty oven thermostat unit.
If the error code reappears after using the oven you should get the thermostat replaced.
Jan 23, 2010 | Kenmore Ovens
665.95802000 f1 - E 1 error code
take the consol off you will find the tech sheet with all the codes. make sure you turn your power off first.
Dec 23, 2009 | Kenmore Ovens
Error Code F2 and F3 on Kenmore free standing stove model 71342
My Magic Chef oven keeps getting a F3 error
Dec 14, 2009 | Kenmore Ovens
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
F2 code on a oven mod#911-41069690
go to repairclinic.com click on repair help, then error codes... scroll to kenmore (it will give you a list by the first 3 digits of model number, who really made the machine.. (kenmore doesn't make anything) then go to appropriate brand and find error codes.
Feb 25, 2009 | Kenmore Ovens
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
Kenmore 30169 Electric Single Oven Logo
166 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
