Question about Microsoft Internet Explorer 8
When I open ie 8 I get the message website error
  • Fixer
    Fixer Sep 11, 2010
    Use firefox
    President:
  • 2,291 Answers
U may have internet settings error check ur connection set all setting to default, for further run reg in out registry cleaner
Posted on Sep 16, 2010
Registry errors
You may have encountered the following message while browsing certain websites:
"Internet Explorer cannot open the Internet site http://<website>.com. Operation aborted."
This really has nothing to do with your browser or your computer. You get this error because of faulty web coding from the webmaster's end.
IE displays this error when it is unable to open a particular element on a web page.
There are many things you can do to troubleshoot this kind of problem.
Upgrade Internet Explorer.
This problem does not occur in Internet Explorer 8. Navigate to Microsoft download Center and click on the "Download" button to upgrade to IE8 or IE9 (see Below).
http://download.cnet.com/windows-internet-explorer-8/3000-2356_4-10910662.html
IE 8
http://www.microsoft.com/windows/internet-explorer/default.aspx
IE 9
Click on "Tools" and select "Internet Options." Hit the "Advanced" tab.
Click to remove the check mark next to "Show friendly HTTP error messages" under "Browsing" sub-headings.
Click on "Apply" and hit "OK." Please note this works mostly for Internet Explorer 6, although there is no harm in trying this on older or newer versions.
Add the specific website that is producing "Operation aborted" error under "Restricted Sites."
Click on the "Security" tab under "Internet Options."
Single-click to highlight "Restricted Sites."
Hit on the "Sites" button and click on "Add."
Type the URL of the website and hit "OK."
This works for Internet Explorer 7, but again, you can try this in earlier versions.
Disable or require prompt for "Active Scripting" when you view the specific website.
Click on the "Security" tab.
Click to highlight 'Restricted Sites" zone.
Navigate down to the sub-heading "Scripting."
Click to select "Disabled" under "Active Scripting."
You may also choose "Prompt" if you want IE to issue a prompt when opening the specific web page or website.
If you are still worried about the registry or need to fix any problems with it
You can run a free registry scan using utilities from http://re7.info
Hope this helps.
Nov 26, 2012 | HP Computers & Internet
When we try to access a Website in IE 8 (Windows Vista) We are getting this message Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; Trident/4.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 1.1.4322;...
I'd suggest downloading and installing Firefox as an alternate (or main default) browser to view the websites giving that message. I think the fix for IE 8 may be too troublesome and / or time consuming.
Jan 11, 2011 | Microsoft Internet Explorer 8
Error message IE
IE Error
Water inlet error. Cause : Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes
Check to make sure the water valves are fully opened
Nov 26, 2010 | LG WM-2277HW Front Load Washer
WHEN I OPEN IE THAN THE MESSAGE APPEARS AS WEBSITE RESTORE ERROR.AND I CANNOT SURF THE WEBSITE AND AFTER SOMETIME IT CLOSES SUDDENLY.SO PLEASE CAN U HELP ME TO RESOLVE THE PROBLEM
try the following steps , close Internet Explorer.
if you are using WINDOWS XP
click start>run, type in inetcpl.cpl , press enter
if you are using windows vista / windows 7
click start> in "search programs and files" type in inetcpl.cpl press enter
internet explorer properties will open up. go to the last tab which is Advanced.
Click on RESET
proceed with the reset and try again
Sep 12, 2010 | Microsoft Internet Explorer 8
Everytime i open iternet windows script host appear with the following data: Line 24, Character 1, Error permission denied, Code: 800A0046, Source:Microsoft VBScript runtime error. Please help me to solve...
It is a Windows Internet Explorer bug that could be fixed by upgrading your IE to version 8. Also, check your "home page"found at Tool => Internet Options and set it to some legitimate website. The error message simply means that the page you are viewing has scripts that return an error.
Feb 02, 2010 | Computers & Internet
Intranet Content not getting uploaded on IE8
uninstall ie 8.0 from add/remove programs and restart the computer and try to access the website using i.e 7.0
Nov 10, 2009 | Microsoft Internet Explorer 8
Constantly encountering an error and needs to close
I think, its some Add-on which is creating this problem in IE.
Please check the Add-ons in the Tools "Manage Add-Ons" Menu and try Enable / Disable for the Add-on which you think is not required for your IE.
Apr 26, 2009 | Microsoft Internet Explorer 8
Internet Explorer Crashes when Closed
I had the exact same problem and was so frustrated I was about to smash my pc with a hammer. LOLZ! Finaly I had enough and decided to update to I.E. version 8 form the M.S. updates site. After the update and a reboot, the problem immediately went away. It hasn't happend since! YAYYY! When he new I.E. 8 started I got an error message which told me tha my HP {Printer} had an I.E. adon that was incompatable with I.E. and would cause it to crash and suggesed that I remove or disable the adon. So I am assuming that was what was causing the crash problem with version 7 as well. I hope this helps others! Try turning your I.E. adon off then restart I.E. see if that helps! If so, it's only a mater of determining which ones are incompatable! PEACE! KreiosK.
Aug 17, 2008 | Computers & Internet
Open Questions:
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; nsapshr 10.0.3) Timestamp: Mon, 7 Jul 2014 20:45:22 UTC Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js
Jul 07, 2014 | Microsoft Internet Explorer 8
See all Microsoft Internet Explorer 8 Questions
Microsoft Internet Explorer 8 Logo
21 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
