Question about Aiptek ISDV2.4 Flash Media Camcorder
When I tried to turn on my camcorder it just comes up with a blank screen. I thought there was a problem with the batteries but its not.....what could be the problem
  • 121 Answers
It may the process that loads options and booting .So the screen goes to white.When the camcorder goes old the problem happen
Posted on Sep 11, 2010
My display screen is blank.why
Ifthe screen of the Camcorder is not working, please follow thetroubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button above the hand strap.
Note: In the above picture, 10 represent the reset button.
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, pleaseremove the battery pack, turn the Power switch to ON for more than 15 seconds,turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps,service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Dec 04, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
I have had a jvc GZ-MG130U for a while. The kids have recorded a whole bunch of things and I finally downloaded it to the PC in order to empty the camcorder. But when I started deleting all the files,...
That's a bummer. I have the same camcorder and yesterday 10-3-2010 mine did the same thing. I deleted some files from the file folder located on my camcorder from my computer (which I learned not to do), went to the disconnect device on the computer and it said "safe to disconnect" so I did. The screen on the camcorder said "connecting to device" the whole time I was transferring files to my computer and after my computer said it was safe to disconnect. After it was safe to remove my camcorder, I unplugged the usb cable and tried to turn off the camcorder and nothing happened. I removed the wall charger and battery which finally turned off the camcorder. I then tried to turn the camera on and same thing as you, Everio sign came on and then the screen went blank. Nothing was accessible after turning the power on. One time an error sign appeared saying something like disc broken, need to restore disc to record video. I tried everything, turning on with wall charger and no battery, pushing buttons while it was turning on, holding down buttons, etc. Finally I tried something that made it work. Don't know exactly what I did, but it started working.
Solution: With the power in off position and the battery removed, as well as the wall charger cable removed, I flipped open the screen, opened the lens, connected the wall charger, turned switch to on position and let it run its coarse. It was on for 5 mins or less then shut itself off. I then flipped the switch to off, let it sit for a few minutes and turned it back on, while it was booting up (this part has no logic behind it) I pushed the "plastic" lock buttons for the battery and a screen appeared asking me if I wanted to restore the hard drive. I quickly clicked yes and all is well. The camcorder is back to factory settings but it at least works. Luckily I copied everything before it crashed. The key for the future is to not delete files from the camcorder while it's connected to your computer.
Sorry for the long post, but hopefully it helps.
Eric
Sep 03, 2010 | JVC GZ-MG130U Camcorder
I have a problem similar to some posted but not exactly..My unit doesn't turn on unless plugged into usb, red light comes on and screen flashes green "insignia" welcome screen then goes blank. no buttons...
If memory serves, this unit requires the battery to be in place and functional to have the camcorder work properly...so your prognosis of a failed battery would be appropriate.
Go Here: http://www.batteriesplus.com/products/546-0/6354-Camcorder-Batteries/437138-Insignia/NS--DCC5HB09/1.aspx
This should be the correct battery for the camcorder.
hope this helps!
Jul 17, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
Camcorder will not turn on without being plugged
If the camera is turning on and is able to be used normally while plugged in to an AC wall pack, but not using the battery, there is probably a problem with either the battery or the internal power switch to go from AC to battery.
Check the battery with a voltmeter to insure you have a fully charged battery. It would also be a good idea to use the voltmeter on the camcorders power tabs to make sure the camcorder is passing the correct voltage to the battery. The amount of volts should match the volts on the battery.
If it's a battery issue, batteries plus has a replacement for this camcorder. If not, it's a switch within the camera (software most likely) and there's not much you can do other that try to reload the camcorders firmware if it is available fromt eh Insignia-Products web site.
Hope this helps!
Feb 08, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
When turn on, screen blank, not operational.
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common in sony. Good luck
Meggita
Jul 15, 2009 | Sony HDR-CX7 Camcorder
Picture in veiw finding keeps rolling so cant see what i am video
As you have noticed, this is not a battery problem but rather a screen problem(the view finder LCD screen) If the image is crisp and clear even though its rolling I would assume that the LCD screen connectors have come loose and can be resolved by taking them off and re-connecting them firmly. Make sure to turn off the camcorder before atttempting the repair just in case you want to do this yourself. I strongly advice you take professional help in fixing it.
Feel free to post back if you need more help.
Sai.
May 12, 2009 | Panasonic NV-DS65 Mini DV Digital...
Razor blank screen...battery?
ok... I thought that might have happened. Good luck with the claim. Let us know how it went. Really, he should be the one trying to contact the other user. That's just good business practices. After all, it was his mistake, not yours.
- Jim
Feb 12, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Smart VLWD450 camcorder
casette compartment is not working. actually it opens but the casette is not coming out of that compartment. any solutions?
Dec 28, 2007 | Sharp Viewcam VL-Z1U Mini DV Digital...
My cell keeps shutting down when i try to turn it on
i have a razor vx3 that was doing this every time i would get a phone call. I returned it for a new phone thought att.
Dec 03, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Open Questions:
Aiptek ISDV2.4 Flash Media Camcorder Logo
88 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
prouddad_1
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
