Question about Zerus Intel Desktop Board D815EEA (Z-D815EEA) Motherboard
HOW TO CONNECT AHDD LED IN ASROCK MOTHER BOARD
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Just parallel to Power LED button you find HDD or IDE LED button, the red coloured wire should be top and the white coloured towards reset connection.
Posted on Sep 11, 2010
I have a ASROCK G31 945 intel MOther board , When i purchased i fiited with IDE CD/DVD Drive . INow is it possible to connect the SATA CD/DVD drive to my mother board. i have SATA connector on my MB ....
You need is an open slot for the drive, an available SATA slot / cord, and a SATA power. It may require you to go into BIOS, and in some cases a driver for the new drive. Don't forget the SATA drivers if you have XP.
GL
Oct 08, 2012 | Intel ASRock G31M-S M/board - Intel...
I have a new pc case on the front panel connectors their is one hdd led +- and one hdd led plug were do they go my case is a EVO LABS E-6690 BLACK/RED, 12CM LED FAN, INC DOOR AND SIDE WINDOW my mother...
Hi Badboy !
you can type the name on the motherboard on Google e.g : asrock m3a ucc pdf
You will find the pdf manual right away. On the 20 th page you will see how to connect the HDD led .I think the case should only have one led for the HDD if it has 2 leds just ignore it because the motherboard has only one place where you can put that led. Be careful and good luck !
Aug 26, 2011 | Computers & Internet
Can you please show how to re-connect power led, power switch reset switch, hdd led &speaker cables to asrock k7vt4a+ motherboard diagram would be appreciated
there must be writen somwhere in the board it self. can you see the panel where you are trying to fit? see the whole board and you see the settings of it. just read what is written downwards to the first pci slots. i think this the setting.
Apr 16, 2011 | Asrock K7VT4A+ Motherboard
Was workin ok but no signal imput now
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Mar 29, 2011 | Asrock K7VT2 Motherboard
I NEED MERCURY AS ROCK MOTHER BOARD DRIVERS
HI
your Asrock P4I45GV
Mother board drivers can be dowbloaded from following links
ASROCK P4i45GV VGA drivers
From
All drivers of *********** board is avail at the
Asrock's Website
Here is the link
and select the desired product(Eg:vga drivers,lan,inf )
and the desired OS
and select the download location
And download
1.
http://www.asrock.com/mb/download.asp?Model=P4i45GV%20R5.0&o=XP
and
alternative
2.
http://drivers.softpedia.com/get/GRAPHICS-BOARD/OTHERS/ASROCK-P4i45GV-R30-VGA-drivers-2kXP-131.shtml
Hope this will help you
Feb 28, 2010 | Asrock P4I45GV R5 Motherboard
I have asrock prescott 800 ddr400 fsb800 motherboard. i bought a new dvdrw that is sata. is this dvdrw compatible with the mother board? where to connect?
Sorry but the motherboard Asrock 845GV (P4I45GV) doesn't have a SATA controller and there for does not have the ability to connect a SATA CD/DVD-ROM drive to the MB. However you can buy a serial ATA IDE to SATA converter which will allow you to connect you're SATA CD/DVD-ROM drive into an opened IDE port. Provided is a link to you're motherboard;
http://www.asrock.com/mb/overview.asp?Model=P4i45GV%20R5.0 Next, is a link for the SATA convertor;
http://www.startech.com/item/IDE2SAT25-40-Pin-Female-IDE-to-SATA-Adapter-Converter.aspx
Cheers'
Mike
Jan 30, 2010 | Asrock 845GV (P4I45GV) Motherboard
Swapped mother board
Hi Paul,
see page 8 number 15 for location. Than see page 19, System Panel Header in your manual.
The basic wire color's for positive are red, blue, green & can also be light blue, light green, light red.
Negative wires are usually white or black. Case wire colors do vary from case to case.
To see pin one shown on page 19, (positive + for hard drive led = HDLED+). Bottom row farthest pin to the left of set. Pin two is above pin one. Pin two is, PLED+ (known as power led). Pin 3 is to the right of pin one & is HDLED- (Hard drive led, negative). Pin 4 is above pin 3 & is also PLED-, (Negative for power led). ECT!
6781222.jpg If your new case has an internal speaker (Used for P.O.S.T, power on self test). This would connect to, Chassis Speaker Header located on page 8, number 16. Again, normally only two wires are used across the 4-pin connector. (One at each end of the connector).
To see ASRock's main site for the 775VM800 motherboard click this link:
http://www.asrock.com/mb/overview.asp?Model=775VM800&s=
Good luck Paul!
Run into a snag, just post the issue here.
Mike
Nov 02, 2008 | Asrock 775VM800 Motherboard
My computer is not working
have u tried to boot into bios switch it over to optimal settrings or default settings and save and try to reboot
Aug 17, 2008 | Asrock 775i65GV Motherboard
Zerus Intel Desktop Board D815EEA (Z-D815EEA) Motherboard Logo
370 people viewed this question
Top Zerus Computers & Internet Experts
David Payne
David Payne
Are you a Zerus Computer and Internet Expert? Answer questions, earn points and help others
