Question about Rubbermaid Sport & Outdoor - Others
When I plug my Vector Rubbermaid VEC212RB portable heater/cooler into my vehicle DC outlet/socket, the red light bar on the VEC212B indicating "Low Vehicle Battery" lights up. What does that mean? What should I do?
  • 833 Answers
SOURCE: thermoelectic cooler not cooling properly
I think you've actually diagnosed your problem. Get that fan moving and you'll probably make this go away. Rubbermaid has a website and decent customer service. If you're in warranty...go there first.
Posted on Mar 09, 2008
DAD5bbbbg
  • 111 Answers
SOURCE: fault light on vector battery charger flashing
Make sure that you have the pos and neg on right.
Posted on Mar 16, 2009
  • 77 Answers
SOURCE: Battery indicator light blinks red on cell phone
that depends on what kind of phone it is. Double check your phone's make and model first.
Posted on Sep 05, 2009
kozachek
  • 122 Answers
SOURCE: Vehicle power cord - red light went out after
Try checking the fuse inside the power cord. To do that, twist the tip off. If the fuse is blown, replace it
Posted on Nov 07, 2009
  • 101 Answers
SOURCE: Broke the 12v DC plug on our Rubbermaid/Vector
A generic plug should work...just be sure to size the fuse correctly to protect the unit. Most thermoelectric units draw about 4 to 5 amps...so a 10 amp fuse usually works.
Posted on Dec 20, 2009
I have a Vector 300 Amps Start It Jump Starter 12 Volt DC power supply. When unplugged the area light won't come on and the battery status lights don't show either. What could the problem be? Sheila
So, want to make sure I understand correctly, when its not plugged in to a power port on your vehicle direct current(DC) a work light on it does not come on. But there is a indicator light saying that there could be a fault.
so, does the key have to be on? and is the storage battery which its drawing its power from been check recently? sounds like its right at the border or past due continuous charging will also lead to a dead battery.
Oct 28, 2015 | Vehicle Parts & Accessories
How do I know it's charging
if you can get your hands on a volt meter attach the meter to the charger clamps, red to red and black to black, turn the volt meter to DC volts (20V scale on most) and turn on the charger. You should be reading at least 12V.
Dec 05, 2013 | JUMP START SYSTEM
Power on Board 450 portable charger light - green flashing
What your seeing there is indicating fully charged.
Apr 01, 2010 | JUMP START SYSTEM
Wiring diagram for tow bar electrics on a 1999 ford galaxy
WIRING DIAGRAM FOR 12N TYPE 7-PIN Black socket or plug
for vehicle road lights
Colour Terminal Purpose Looking at the Socket towards the plug.
Looking at the Plug towards the socket. Yellow 1 (L) LH Indicator wd_black_socket.jpg Blue 2 (54G) Rear Fog Light (or Aux.) White 3 (31) Earth Green 4 (R) RH Indicator Brown 5 (58R) RH side Light Red 6 (54) Stop Lights Black 7 (58L) LH Side Light
Mar 17, 2010 | Ford GT Cars & Trucks
On a vector jump start system, does the green light have to stay on to indicate that is charged> what if only the 2-3 red light go on when i press the test button?, when the green is flashing while...
2 - 3 red lights indicate not fully charged. Green light = fully charged.
Not fully charged does not mean it will not function. For best results, your device should be fully charged. If you have an emergency and are not fully charged, it will not hurt to try to help with a partial charged device IMHO
Thanks for posting at FixYa.com
Dec 13, 2009 | JUMP START SYSTEM
Broke the 12v DC plug on our Rubbermaid/Vector Thermoelectric cooler. Can't find a specific replacement plug. Any specific specs I need to look for in a replacement?
Dec 09, 2009 | Refrigerators
2nd season with 400 watt vehicle 1024 inverter. The
Restating the question - 400 watt inverter is turned on and running with the vehicle turned off.
After starting vehicle the red light of the inverter is on with no power output from the inverter.
If you turn the inverter off then on inverter operates normally.
Solution - this is normal operation - my inverter does the same thing. When you start the vehicle
it draws a lot of current from the vehicle battery which causes a drop in battery voltage. Most inverters have a low voltage input safety and will fault the device.'
If the problem is turn on inverter then the red light starts flashing... I am thinking you
have the same problem as the one I replaced - it broke... I am sure some capicator
or other component in the circuit failed... My solution was to purchase a new one...
Mar 03, 2009 | Inverter Vector 400-Watt Power
My Vector Vec157 Flashlight won't Charge...
It is the battery, I have a similiar Vector light for a few years and tried re-charging the battery but only the little LED light would come on. I have another Vector light, same model and switched batteries from the worjking one to the non-working one and now it works fine.
I then proceeded to purchase a new battery for the non'working one and when I arrived home I installed it and turned on the main light, still won't turn on, I tried the LED's, they work. I figured maybe the new battery needs a good charge so I plugged the charger in and charged the light for 12 hours, still no main light.
I guess the new battery is defective, so now I will return it and exchange it for another one.
Aug 22, 2008 | Vector 20 Million Power Series Spotlight
Thermoelectic cooler not cooling properly
Mar 08, 2008 | Refrigerators
Sport & Outdoor - Others Logo
74 people viewed this question
Top Rubbermaid Sport & Outdoor - Others Experts
Are you a Rubbermaid Sport and Outdoor - Other Expert? Answer questions, earn points and help others
