Your guages will not likely goto the max. Your compressor should be rated at 100psi maximum, maybe 125psi. Consult owners manual for this.
You likely have a leak at the popoff valve. Let the tank air fill back up, then turn off the compressor. You should be able to hear the leak, and follow the sound / air movement to pinpoint. At this point, you can determine if it is something that you are able to fix yourself, or if you have to seek out a service center / return to dealer or retailer.
Hello
Could be a bad pressure relief valve.Also have a look at the oil level.
