Question about Whirlpool 24 in. DU1148XTP Built-in Dishwasher
Dishwasher was blinkin clean light 7 times in a row. After researching internet was able to clear codes. However went to run dishwasher again and it buzzes when in wash cylcle without washing
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Sounds like you are not getting water to machine or it is not recirculating. Check for water and recirculation noise while running.
Posted on Sep 11, 2010
Washer stopped in mid wash. Clean light came on and flashes 7 times. Pressed clear went to 2 and finished. Pressed start light flashed 3 times won't start.
remove the bottom kick panel,you'll see a tech sheet there in the plastic bag,it will tell you how to check to see if the heater or board is bad,the light will flash 7 times,it's an error code telling you that there's a heat problem.
Feb 20, 2015 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Clean light blinks
clean light blinks is a form of error codes. The most common is a heater circuit error, 7 times then a pause is the heater. to clear the code press the heated dry then normal in a key dance 4 times. this starts a diagnostic cycle, takes several min to complete. let it run. it will work until it sees the fault again. this code is caused when the main control does not read a water temp increase 3 times in a row. If this continues call for service.
Jan 08, 2012 | Maytag Dishwashers
Clean light flashes and dishwasher will not work
when the clean light flashes its displaying a fault code based on the number of times it flashes...if it flashes 7 times then pauses then flashes 7 times again its displaying error code#7 if 4 times then pause its code#4 ect.
This tip i wrote will tell ya how to reset the board since sometimes its just electrical anomilie..reset the board and if it again flashes let me know how many times in a row it flashes and i will determine which error code it is , heres that tip to reset the control board http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
Sep 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The dishwasher will not come on and the clean light is flashing.. We have hit the cancel button but the light is still blinking. We have also un plugged the dishwasher to try to reset it and the light is...
I have wrote a tip about resetting the control which i have posted below. My question though is how many times in a row does the light flash,depending on the consective times it flashes before pausing them flashes the same number of times indicates what error code it is...example if it flashes 7 times in a row that is error code 7 if it flashes 4 times that is error code 4 and so on
here is that tip of what ya need to do to reset the control board
http://www.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
please reply with how many times it flashes then pauses then flashes again and i will determine what error code is being displayed
GENE
Sep 17, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
I have a kitchen-aid dishwasher model # KUDio1ibl6 and it will not come on and the clean light flashes 7 times then pauses and blinks 7 time again. Do you have any Idea what this code stands for I do not...
Hello Asa,
The light blinking seven times is a error code specifically it's error #7 .The E-7 error indicates the part called the flow meter is bad. To clear that error code and get the dishwasher to start push within 3 seconds
HIGH TEMP WASH -HEATED DRY-HIGH TEMP WASH- HEATED DRY
then push CANCEL sereval times to dishwasher shuts off..it should start and run then
If the blinks 7 times again the flowmeter will need to be replaced
ON some models the "HIGH TEMP WASH" button is labled power scrub instead of high temp wash
so in that case push POWER SCRUB-HEATED DRY-POWER SCRUB-HEATED DRY then cancel as described above
In case the E-7 error returns and the flowmeter needs to be replaced the part number for it is W10195536
Gene
Aug 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light flashing and unit wont run
you can open the lowe racess panel of d/w and you find a techsheet/ trouble shooter, in ther they will explain how to reset a clean light blinkin 7 times.. you can try pushing the "sani-rinse"---"heated dry"--- "sani-rinse" --- "heated dry"... toggling these buttons will triggor a test mode, youl know your in it for all the lights will light, close the door and wait 30 secs or so, the reopen door and cancel cycle, after it runs for 2min it will be ready fro you to start using again.. of the clean light issue returns, id recommned calling for service
Jan 24, 2009 | Whirlpool Dishwashers
Lights flashing on clean. Program does not take.
Jan 07, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
My kenmore elite dishwasher will not start.
Thanks to another post, i found how to clear this code, by alternating between the High temp dry and air dry buttons the dishwasher went into diagonostics, then cleared. I found then that the washer would fill but not wash then it would drain. I found the motor was almost seized, I am replacing. The 7 flashes must be a code for the motor going on overload.
Oct 08, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool 24 in. DU1148XTP Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
