Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Lid safety switch how to get out to change how to
Lid safety switch how to get out to change how to take washer apart at top
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Remove screws from rear of timer console, pull console forward and hinge it up to expose brass colored clips. Remove these clips and unplug lid switch connector. The cabinet will now hinge forward and you can remove it to access the lid switch.
Posted on Sep 11, 2010
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
Washer stopped after filling
I know this may sound like a stupid question but "is the lid closed completely "? if so open the lid and take a plastic knife and depress the safety switch on the top of the machine and see if it works. It will be located on the top of the machine usually it is an oval shaped hole under where the lid closes down on it. If that works then you can open the top of the machine and adjust the safety switch.
Sep 28, 2014 | Whirlpool LSR5132PQ Top Load Washer
Does not spin
Could be a bad lid switch or deive coupling. This video will help.
Aug 01, 2011 | Whirlpool LSR5132PQ Top Load Washer
I fill machine with water but have top slam lid down and put some thing on top of the lid for laundry to start. now it just won't start. what do i do?
lid safety switch not engaging,had the same problem with my atlantis.turns out the plastic hinge pin bushings in the body of the washer where the lid is hinged. breaks apart.allowing the lid to come out of alignment. easy fix and the bushing is only about 2 bucks each at an appliance parts store...
Dec 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My Kenmore Elite Oasis HE model number: 110.27072603 washing machine shows LID error code. It wont work at all.... went half way through cycle... help.
Greetings,
this washer has a lid switch problem...or possible main board failure, but lid does concentrate on the lid safety switch. If you remember when you open the lid it stops..well, its a safety feature and prevents tub from spinning with lid open...this one is more difficult to service if your not use to working on washers...try unplugging machine and leaving off for awhile...does the door lock? check switch for lid fault
Nov 25, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Lid will not engage safety switch , closing lid does not engage safety switch , i have to wedge something in it
Either the pin on the lid has broken, or the switch mounting bracket has broke or the screws losened and the pin cannot push the switch enough. If the switch is mis-positioned, you'll have to open the washer top and check out the switch mounting. Goodluck< Macgivor
Jan 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
How to Find Lid Switch on Maytag Washer
i would recomended, becouse it is not just lid switch, on this model it is a small conroler..but if you still want it...it is on thge back of your top lid, right on the center..open your lid and look under
Aug 25, 2009 | Maytag LAT3600A Top Load Washer
My washer will not agitate after filling with water...
is the lid closed? if it is the it is the lid close safety switch you can by pass the switch but i would replace it if u do bypass unplug the machine its a safety thing. Tom
Jun 29, 2009 | GE WBSR3140DW Top Load Washer
Need to know about safety switch on washer lid
First, this machine has an electronic motor. Check to see if belt is broken. If not then unplug for 2 minutes, plug back in and open and close lid 7 times slowly. This will reset motor. A common problem with this machine. I dont think it is the magnetic lid switch.
Jun 15, 2009 | GE WBSR3140DW Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
167 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
