Question about Intel DG965SS Motherboard
My DG965SS mother board just shuts down when it want to. Some times it will just reboot right in the middle of whatever and some times it tries to reboot but freezes on the start back. I have reformated the SATA drive and reloaded windows XP Pro. While still loading some of the drivers it will shut down and lock. I have finally gotten the drivers loaded and still the same thing. Sometimes it will let you work for a minute or maybe 15 minutes and sometimes just 2 minutes and then BAM shuts down. It seemed to be locking on the DVD Burner so I disconnected that and it helped for a minute but not much.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
1. Blow the dust on the motherboard and on the SMPS.
(don't use vacuum side) if possible use the soft brush to remove the hard dust.
2. Remove the cpu heatsink carefully, clean and replace the heat sink compound. (Take the help of a guide or service engineer)
3. Open the memory from the slots and replace it back after cleaning.
4. The above should solve the problem, finally replace the SMPS or get the motherboard tested.
Posted on Sep 11, 2010
    Genius:
  • 1,400 Answers
Hello
I have a intel dg33bu.Have a look at the internel fans.Are they clean.
The processor fan and heat sink need to be clean of dust and dirt.
Last- It may be a good idea to put some fresh thermal paste on the processor.
What you are describing sounds like a heat issue,runs,heats up then shuts down.
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
I have a virus on my computer and i it wont let me access anything and i want to reboot it but i dont know how
try a hard shut down by holding power button down till computer shuts off. if this doesn't work unplug from power source and see if you can reboot. of can't reboot. may have problem with mother board. this then goes beyond my scope.
Apr 02, 2011 | Dell Inspiron 1545 Notebook
I have DG965SS mother board and I am about to buy video card PCI-E , what I need to do to have this card working and not using the on-board craphic ?
When you already purchased a new PCIE card for it what you need to do is to just plug the video card to the mother and then power it on and computer will automatically disable the onboard video card and then once computer is up run the setup disc for the new video card and install all the software for it and you;re ready to go now.
Mar 13, 2011 | Intel DG965SS Motherboard
This is the 2nd time this happened. First time cpu shut clear down would not boot up. Mother board was replaced about 18 months ago. Now the same area under the mouse pad got super hot and all the USB...
try cleaning your computer of dust using a fine air blower from a compressor making sure that there is no MOISTURE in the air line specifically around the CPU central processing unit dust causes static to build up in a computer causing it to overheat any many other problems
the usb
control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s
to do this right click on the ? x ! select reinstall driver
also
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
Jan 05, 2011 | Computers & Internet
Satellite M45-S351 locks up won't shut down. First thing, may lap top would not shut down so we had to use the power button, then after some time 2-3 the unit decided not to boot up. we copyed the hard...
I think it is a prob with the mother board.........no need t change RAM or hard drive........they dont cause this type of prob. Ur mother board is not accepting the shutdown command.
Try the following command in command prompt:
shutdown /s /f
May 23, 2010 | Toshiba Satellite M45-S351 Notebook
Emachines w2828 keeps shutting down reboot/Screen Freeze
I dont thing this is a virus problem but a heat problem. if you dont mind getting inside the box see how clean it is and put your hand on the power box case .. then unplug all the hardware except the mother board then turn the unit on, if it goes on then plug 1 hardware at a time.
Sep 04, 2009 | E-Machines eMachines Desktop PC
No power
This suggestion is a real long shot but at least it something you can try. It sounds like you've already ruled out all the other stuff I was going to suggest. Try replacing the CMOS battery on the mother board. It's one of those large flat batteries about the size of a nickel.
Jun 03, 2009 | Gateway 505GR PC Desktop
System is not shutt down
what happens if you shut down by unpluging or turn the surge pertector off.
if you did that you reboot into safe mode and check out the system and bois on the motherboard
rod????????????
Feb 04, 2009 | Intel Motherboard
Computer won't acknowledge power souce - shuts down
Try taking the battery completely out and see if it works then.
Mar 26, 2008 | HP Compaq nc6320 Notebook
Intel DG965SS Motherboard Logo
211 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
