Question about EliteGroup PM800M2 Motherboard
Hello I have an pm800-m2 motherboard with Vt8237 chip and am having problems installing a new western digital 500gb sata hard drive (the old drive was a 200gb pata) It seems the bios is not recognizing the new drive, even though I followed directions to set the bios. ty Lea S
  • mamaredwolf Sep 11, 2010
    Thank you shiva_giga for the answer. Unfortunately, the BIOS updates the manufacturer offers do not help with this problem. I will still try the card although forums I have read have said cards don't seem to work either. I wish there was some sort of manual for my particular BIOS since the motherboard manual has very little info on it. TY
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
1. Try updating the BIOS (if available) or
2. Install a PCI to SATA card and connect HDD through it.
Posted on Sep 11, 2010
Can't get ECS PM800-M2 to boot to SATA drive.
You need to make sure that your SATA drive has an Operating system on it. It can't boot if it only has a data drive.
Feb 19, 2013 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Need a manual for pm800-m2 motherboard
Hello Gerard, my name is Arman (online alias: thedrain)
Attached in the below hyperlink is the manual that you are looking for...
ECS
Jan 16, 2013 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
I can't install a 500gb western digital sata drive to my vpm800-m2 motherboard it won't read the drive
When you install the drive, go to "Computer" or "my computer" and right-click on the icon.
From the dropdown menu, choose "manage".
Click on Disk Management. You will see your C: drive there and it will tell you what it is.
You will probably also see the new drive, but it will appear as unknown. You can right-click on it to initialize it and format it if it is not formatted.
There you go.
May 09, 2011 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
MSI K8T Neo 2 not recognize Hitach 1 TB Sata
This is a quote from VIA:
"CHIP FIRM VIA issued a note to its customers telling them of problems with chipset support for hard drives using the Serial ATA II standard.
It said that VT8237 and VT8237R chipsets don't provide forward compatibility for S-ATA II, which is important as hard drive makers are beginning to manufacture this type of drive.
But Via is readying the release of VT8237R Plus, which will solve the problem. This means that motherboard makers that use the former chipset should clear their inventory before September.
Hard drive manufacturers position with S-ATA II is as follows, said Via in its note. Western Digital and Samsung are already shipping these devices, while Seagate and Maxtor will start shipping them during this quarter.
If you connect S-ATA II drives to an old Via chipset which includes the VT8237, VT8237R, VT6420 and VT6421L, the devices won't be detected.
Some mobo makers, such as Epox, have already responded to the problem and have warned their customers to seek the support of hard drive vendors. In a letter to its customers, it said that they should also check the specs of other manufacturers' Via based motherboards."
Jan 11, 2010 | Computers & Internet
I have a 320 as my primary and i want 2 ad a 500 sata wd how do i set the pin jumper for secondary on my new one and the factory 320 has no jumper at all thanks
The SATA Drives do not need jumpers to set primary and secondary drive positions. Each sata drive gets it's own connection to the motherboard. Check you motherboard diagram, and make sure the 320GB drive is plugged into the 1st sata controler, and that the 500GB drive is connected to the 2nd.
Oct 11, 2009 | Western Digital Caviar 500GB Internal SATA...
Need diagram of how to hook up my western digitial sata harddrive to mother board a asus a7n8x-e deluxe
this motherboard does not support your new Hard Drive. SATA is a connection type required for your hard drive. Your motherboard supports IDE connector. You probably can get a pci card that allows you to attach the hard drive.
May 24, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
I can detect no SATA' HDD
The ECS PM800-M2 only supports SATA 1.0 hard drives. If you are using a newer SATA 3.0 hard drive, there is a jumper on the hard drive which has to be set to SATA 1.0 in order for the VIA 8237R chipset southbridge (which Is on your ECS PM800-M2) to recognize the newer SATA 3.0 hard drives. This Is applicable to all motherboards with the Viatech PM800 / 8237R chipsets. Note: the location for the SATA 1.0 / 3.0 jumper varies on each brand of hard drives. Also check If SATA Is enabled In the BIOS and select IDE mode.
Apr 23, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Feb 09, 2009 | VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400...
PM800-M2 Restarting
reformat means that you have to install an fresh copy of your operating system to the hard drive. if you do have a cd of your windows installer like windows xp, just put it in your cd drive and restart your computer and boot from that cd. be sure to erase the partition that has your corrupt operating system installed ok to replace it with the new xp that your going to install...
that wasn't to hard was it?
Apr 30, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
EliteGroup PM800M2 Motherboard Logo
166 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
