My friends flat screen monitor started to vibrate the other day. I had her check the cables but still picture vibrated. No obvious sources of interference so she bouhgt a new monitor. Same problem.She tried to change the moniter refresh rate but same problem. Any suggestion?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
If you have tried increasing resoulution as well as refresh rate then,
Try to use TFT, I hope a strong High tension wires may be near your house. (TFT's are less affected by this interferences)
Posted on Sep 11, 2010
How,to,stop,block,constant,vibration,in,the,appartment
Moving would be your best option. Everything on the planet vibrates due to external sources. It is called "Natural Frequency".You need to find a building that is more solid in construction and does not transmit vibration. A critical natural frequency vibration can result in total destruction.
Oct 05, 2014 | Cars & Trucks
Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Pictures on screen gets elongated frequently.
First check its signal cable for loose connection reseat if ever. If it does not help.We will come down to its internal circuitry.Check its vertical IC for loose connection or failing IC, its supply filter capacitor and other capacitor connected to it.
If you are not even familiar with electronic servicing I suggest you do not work inside its circuitry.
Mar 11, 2009 | LG Studioworks 563N 15" CRT Monitor
22" Acer flat screen monitor
this sounds like an electrical fault or failing component, within the Monitor.
Check the cabling, to ensure it,s not damaged-broken-kinked et,c. by carefully moving the cable gently side to side and up and down.
If it puts itself right for a second or two. you can assume its a broken internal wire, within the lead.
Or a dry soldered joint-Connection.
Mike @ compurepair.
Sep 16, 2008 | Acer AL2216WBD LCD Monitor
Screen Shaking/Vibrating
Yeah, Degaussing is basically resetting the magnetic field inside the monitor. go into the menu options, and search for that option. if this does not work, then your monitor is really old, and needs replacing.
Jan 26, 2008 | Batesias V172RTNRA 17 in. LCD Television
Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Nov 06, 2007 | Soyo Dymond DYLT037A Television
Distorted picture
It's possible your video card or monitor is going bad. Which type of monitor do you have? If it's a CRT then my guess is....monitor.
Check all your cables and connections first.
If possible hook up a known working monitor to rule out memory or video card problems.Monitors have a refresh rate but I don't
recommend doing this without supervision or complete knowledge.
Check to make sure you don't have any interference close to your monitor. Interference would/could be: magnets/speakers/radio's/televisions/microwaves (not sure about micros.
If your have a LCD monitor I'm not sure all these suggestions apply.
Sep 14, 2007 | KDS Radius RAD-7 17" Flat Panel LCD...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
