Question about Ovens
Globe & element replacement on Omega 00674xa - Ovens
Can I remove the top element in my oven?
Yeah you can. I think you just snap it off I think the whole thing can come out.
Sep 13, 2014 | Ovens
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
My sister's oven element burned out. Never having replaced one before, I asked a friend how to get it out & he told me. I asked about turning power off & he said as long as the oven is off no need....
First, you should always turn the power off to replace the element. One side of the element always has 120 VAC applied and it turns the oven on by applying 120VAC to the other side giving 240 across the element. Most ovens have L1 branching out to both the bake, and broil elements, and it also branches out to the control board and all of the switches that run your top elements. If you don't have an element in the bottom, its likely that L1 is grounded out and is tripping the breaker as soon as it's turned on. So if you install the new element it should fix your problem, however if it doesn't you might have burned up the L1 wire somewhere and will just have to trace it back.
Jan 30, 2011 | Ovens
How can i change my omega oven element and how to i find out how many watts the old element is
Hello,Is your element fixed to the back wall by (1)Two Phillips head screws or (2)the ends of the element are about "8" apart and held in with 2 clips.Switch off the power on the main switch board marked RANGE,STOVE OR OVEN.
In case of (1) unscrew and take the element out,pull off the 3 push on connectors,get new element and do it in reverse.
In case of (2) get a small screwdriver,push the clip just above the tube from the element going to the back and the clip should jump out,do the same for the other side,lift up the element a 1/4 and pull it out carefully not to loose the cable as they are very short
Thanks
May 28, 2010 | Ovens
My wife was cleaning our smeg. She removed element at top of oven and she said it "arked". Now light inside oven and oven itself doesnt work?
Your oven should be wired to a dedicated electrical switch, in your meter box. It has probably just tripped this switch and fused the globe.
remove the globe cover(quater turn anti-clockwise) and globe and reset switch. Of course you need also to set the digital clock, or oven will not work.
May 02, 2010 | Smeg Ovens
My omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Mar 18, 2010 | Ovens
Omega oven model number is OO910XA
If it is a common problem with Omega, they may not be ready to admit it. Since it occured 2 times, possibly the hinges use nylon rollers for smooth and quiet operation, but the hinges are not well shielded from the hi heat of 500-600 degrees and the nylon parts fail after a few months constant heat exposure. There is a common problem that happens with oven doors when they do not seam to close tight: besides being old and normally worn, if a door is leaned on while it is open, the hinges could be stretched and then they will never allow the door to close tight. This has happened to many ovens regardless of age, and the customer never realized that the weight or pressure they applied to the door when in the open position has done damage; yet they wunder why the door does not close well. Goodluck,Macgivor
Jan 27, 2010 | Ovens
How do you change the oven light? Cannot undo light cover.
Most oven lights have a wire over the glass globe, pop it sideways & remove the globe.
Nov 30, 2009 | Smeg Ovens
I need a manual for omega oven,model not known.
Hello. If your stove is manufactured by Omega Appliances, it appears that they no longer produce it. That said I can speak to your heating element issue. When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
If you would like to contact the Omega Appliance company directly, you can reach them as follows: http://omegaappliances.com/contactus.php
Nov 20, 2009 | Ovens
Ovens Logo
77 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
