Question about JVC AV-65WP84 65" Rear Projection Television
I have a JVC rear projection TV. from the frot it looks like the green color is sagging. we took off the back panel & the green lens... it looks like there is liquid under the lens & that it is not full. can this be fixed? is it something we can fix ourselves?
  • JVC Master
  • 8,457 Answers
The tv pictures cloudy or hallow?Yes,than the R,G,B CRTS Tubes guns require changing it coolant liquid.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to used.But just R,B,G colors lines mis alignment,colors shadows or 3D pictures,this problems is a convergence problems,it dead.The tv convergence board require changing the 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop,will cost u $300-350 for parts and labors.
Posted on Sep 11, 2010
  • 2 more comments
  • jeni_le77 Sep 11, 2010
    the over all pic is kinda fuzzy... like the colors are blurred(??) when i looked down into the green lens i could see the pic with the exact same dip i color that we see on the tv. the pic almost even folds over at some points... for example whe the credits roll, u see the name go toward the top of the screen, once it hits where the green is dipped the colors split, one keeps going up and the green goes back down about 1/2 inch... almost like it just falls off a cliff.
  • Chi Chu Sep 11, 2010
    This is colors lines R,G,B mis aligment,This problems is the convergence board problems.The convergence board require changing 2 STK convergence ICS and some or all it resistors.Will solved pictures R,G,B convergence problems,as stated shop,will cost u $300-350 for parts and labors.
    ok... i have some additional information... it has been repaired 2 times before back in 2007 and the info on the back says: Max Leak: 500 NA
    Max Measured: 190 NA
    Serial #: 16898496
    W: 87118
    I have done the auto convergence thing thru the menu as well
    U done the auto convergence run but all the - R,G,B colors lines dosen't match up ferfectly, data stop midway or same picture's result as before?Yes,than the convergence board require changes 2 STK convergence ICS and some or all it resistors.The convergence board parts are dead or dead again.
JVC HD 56FN97 No RED color
Does menu have any red? Yes = digital video bad; No is light engine bad.
Mar 31, 2014 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
JVC Hd56fn97 56-inch 1080p Hdila Rear Projection Tv with all blue color green
Talk to JVC as I have suggested and this is likely a known problem: loss of any color, picture upside down etc requires a upgrade to correct and I have seen about twenty sets with their name like this with this kind of problem.
Dec 11, 2012 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
Screen at top has a sag look to it what couses this also the coler dosent match up
your convergances amps have failed not a bad job but suggest you have a tech take care of it
Nov 24, 2009 | Hitachi 53UWX10B 53" Rear Projection...
The tv picture looks like should be wachting it whith 3d glasse
This is a very common failure on Projection TV sets. Its called a convergence failure. Here are some common symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around objects on the screen.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Magnavox 60'' rear projection screen tv
That oil is glycol and is a coolant for the tube. Hope you didn't get the oil on the circuits because it is conductive and the tv will not operate with the oil on it. Must be completely full. Can be bought a electronic parts distributors or a tv shop could order you a bottle. Hope you just removed one tube only. Make sure you seal it back good
Dec 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
JVC AV-56WP74 projection TV green sagging and can not be adjusted out.
The convergence amps need to be replaced. If you're having a shop do this call around and ask what they charge for repairing the convergence. If you're doing this repair this set uses two stk392-110 Sanyo built amps. You will also need to test and possibly replace one or more of the 1.5 ohm feed resistors in that circuit.
If you're doing this at component level try Acme in Florida for amps and resistors: 1-800-575-9833 http://www.acme-sales.net/index.shtml and if you're doing this at modular level send it to PTS http://www.ptscorp.com/ 1-800-844-7871
Bill
Nov 06, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC 48WP74 HDTC rear projection
While it is true JVC tubes rarely fail, they can give trouble.
Another possible solution is bad screen / focus block......
Remove lower front grill panel and access board...Check for
smooth adjustment of RGB screen and focus.....let me know....T..
Sep 28, 2007 | JVC AV-48WP74 48" Rear Projection...
Green Convergence on a JVC 56" rear projection t.v.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Aug 27, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-65WP84 65" Rear Projection Television Logo
103 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
