Question about Panasonic Televison & Video
Blinking green and then yellow light continiuously wth no picture
  • 85 Answers
Hi there.sounds like the lamp has failed.these usually go with a pop and shatter...remove the lamp and have a study... hope this helps, steve
Posted on Sep 11, 2010
I have not picture.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jan 23, 2016 | Televison & Video
Why are green horizontal lines are appearing, too much yellow colour and green light blinking red?
These horizontal lines are vertical flyback lines and would indicate
one or more of the tubes cathode drive circuits are defective.
As the picture is predominantly yellow this would indicate excessive drive to red and green guns. Check the red and green video output stages especialy any clamping diodes.regards from Vintie
Sep 19, 2013 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Wd60c9 lights blinking green sometimes,then yellow and finally red and no picture for any significant length of time
2 possibilities. First, the bulb which allows you to view your picture could be burned out. If that is the case, your tv will turn on and you will hear audio but no picture. $85 for a new warranted bulb from Shopjimmy.com. Second possibility. If your TV is on with no picture or sound, you probably have a light engine problem.$325. I don't think it's your light engine. Just don't have enough information. Check the first possibility first. The bulb takes less than 5 minutes to replace. Don't buy just the bulb, buy it with the housing. It doesn't cost more, it costs less and saves a ton of aggravation. Don't touch the bulb with your fingers, use latex gloves when working on electronics.
Feb 23, 2013 | Mitsubishi WD-60C9 60" DLP HDTV
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
I have a Samsung tv that has no place to plug in the yellow cord. It is a new high dollar HDTV what do I need to get the wii to play? No, there is no yellow hole, the picture is black and white, with...
The only way I was able to get around this was to plug into use component 1 then plug the yellow into the green on the far right. The problem I now have is that I can only use component 1. When I plug a dvd or wii into component 2, it shows still shows up in black & white, even when I plug the yellow into the green. I am not a happy Samsung owner.
Dec 25, 2009 | EA Sports Tiger Woods PGA Tour 08 for...
Green and Yellow Light blinks when I turn on my camera
HA, I got the exact same symptoms on my C5050!!! First the yellow light flashes for 10 seconds then the green one flashes. I believe the internal fuses are blown, there are 2 and they are surface mount so they are like 2x2mm so they are SMALL. Im going to have to jump them with a blob of solder on top. It is useless in its present state
Nov 10, 2007 | Olympus Camedia C-4000 Zoom Digital Camera
Televison & Video Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
