Question about Kenwood KAC-7203 Car Amp
My red light on my 1000w amp wont turn on to power my subs. the blue one is the one one to turn on can anyone help me
  • 32 Answers
Make sure that you have a good ground, make sure you have the right amp turn on wire, and your power wire is fused, best solution is to have it professionally installed! Amp install is very basic if you are having a hard time with that, I wouldn't attempt to try it or have one of your buddies install it! FRIENDS DONT LET FRIENDS INSTALL!
Posted on Sep 12, 2010
Cadence 400 watt active sub green light on, no sound from the sub. whats wrong?
proceed according and fix it. However yi\ou must read the diode LED for diagnose. God bless you
Mar 26, 2013 | Exercise & Fitness
Legacy 1000w 2 channel amp worked awesmoe then just stopped working after a few songs. Didn't turn up too loud. Didn't have the settings too high. still getting power (amp light on, led lights...
Open your speaker box up most likely the jumper from the inside of the box to the subwoofer itsself is broken free, Usally when they have lights around the sub woofers there seperate leads, bet 10-1 you have loose wires inside the speaker box
Mar 25, 2013 | Legacy Audio ICON LA2770BK 1000W 2-Channel...
I have 2 10" Sony Explod Subs and a 1000w amp. My fuze was blown but i bought a new fuze that was stronger. My system is still not working.
the amp has power, ground and emote turn on? is the amplifier lighting up? is it going into protection?check the wiring to the amp before you suspect a bad sub and amp
Nov 01, 2012 | Sony Car Audio & Video
What is wrong with my 1000w sony xplod amp?
need repairs on the inside usually when u see that fuse melt something else probably melted on the inside. something is grounding out the amp on the inside . get it checked
Jun 05, 2010 | Car Audio & Video
PDX 1.1000 amp overheating?
Hello thefatman69e,
The Alpine PDX-1.1000 is a physically small amp to produce the power that it does. The result is that it has less physical area for heat to dissipate. Running at or near it's maximum output into a 2 ohm load, it needs some serious airflow to keep it cooled down. I'd look for some way to get more air to it.
Hope this helps.
Sep 21, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Amp turns off for a bit and back on when it hits hard
You do not have enough power coming from our car battery, your alt. may be going out. Look into a 5 farad power cap to store more power...
Apr 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
ALPINE PDX 1.1000
well you would have to look into the ohms of the amp compared to the ohms of the speaker. If the ohms are different you would have to hook them up in a different way. check the RMS on the speaker as well as the amp, this can also be sufficed by wiring it different if ohms match up properly! Hope this helps you out and if this is not the case let me know.
Feb 28, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 29, 2008 | Kenwood KAC-9152D Car Audio Amplifier
RED Port light on AMP?
are you sure its not PROT?
the amplifier is protecting itself from fire because of something.
Disconnect the subs. and turn on.
if it comes on normally, the subs are at fault and will need attention. If the light still stays on, you hafe probably blown an output on the amplifier and it will need repair.
Dec 24, 2008 | Sony XM-2200GTX Car Audio Amplifier
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
Kenwood KAC-7203 Car Amp Logo
245 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
