Question about Vizio VW32L 32 in. LCD HDTV
I have sound. but is waiting for picture. i have horizal lines but not veritcal
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that the inverter board is fine so it is either the T-con board in the unit has gone bad and/or it is not getting the required 12vdc from the power supply unit. If you have knowledge of internal circuitry of the unit then you can open the back of the unit and check the T-con board which is the last board before the LCD panel. Usually it is available with the LCD Panel. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 11, 2010
Veritcal yellow line on 50" sceptre tv
The edge ribbon connector may not be connecting (on the inside of the tv). Cure is foam strips between screen edge connecters and inside cover. Or, Memory chip (used to make the picture appear), may be bad. All flat panel tv's use a memory chip to make picture appear (it is digital after all). And if memory chips are bad, picture will have lines, jags etc. But it sounds like you have edge connecter problems. Place foam between inside cover and screen. TV may have been thrown around in shipment, and edge connecters came undone. They're very lightly soldered on some sets.
Dec 25, 2013 | Sceptre Televison & Video
I have a Sanyo DS13590 abt 6yrs old. I have sound But no Picture just a line across screen.
you need to replace the voltage regulator and the horiz out transistor on the main board
Oct 01, 2009 | Sanyo DS31520 31" TV
Picture goes into horizontal lines while watching then you shut it off for 10 min. or so and it resets it self
solder connections in horiz.drive/output circuit.also solder the flyback transformer.if only 10 minutes you need to solder in the
horiz.circuit area.get a magnify glass and usually will see hair line cracks around the
components.
Jul 17, 2009 | RCA TruFlat 27F520T 27" TV
Blue vertical lines on tv when turned on....now no picturs.
the guns gone bad inside needs to be replaced.
Apr 22, 2009 | Televison & Video
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Quasar TV sp 2724E Loses the picture
Sounds like a failed vertical amplifier circuit. This is normally primarily contained in an integrated circuit mounted on a heatsink.
There are other possibilities along the line but the one above is the most likely.
Now all you need is a TV repair shop that is still in buisness.
Jan 03, 2009 | Quasar SP-2725 27" TV
No power Up , No Sound , No picture
Requires careful, meticulous soldering of horiz drive circuit +
rebuild power supply.....requires four parts......Horiz out xistor,
two converter xistors and one resistor....would you like part list?
Nov 22, 2007 | Sony KV-32S45 32" TV
Horiz. sharp line from 2 inch bottom
If the screen is part of your laptop/notebook/netbook, try to connect an external monitor to the VGA port, to see if the video-card in your computer is generating the "weirdness".
If the screen is an external monitor, try connecting it to a different computer, to see if the "weirdness" follows to the new computer,
implying that the monitor is faulty. Also, connect a diffferent monitor to your computer, to see if the video-card is causing the problem.
Sep 22, 2007 | Computers & Internet
No picture has sound, then picture comes on after a while
check for a problem with the horiz.output circuit. maybe bad solder connections or the horiz.osc.
Sep 15, 2007 | RCA F27442 27" TV
Vizio VW32L 32 in. LCD HDTV Logo
41 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
