Question about Janome Memory Craft 10000
I have a Janome HT2008le and I keep getting a 'E1' then followed by and 'E2' on the screen and I don't know what to do. It just shows that then beeps and beeps. I have searched everywhere to troubleshoot but can't find anything. Anyone know what this means? I would send it in to the closest repair service but to send to a qualified Janome repair centre is going to be $80 away. Please help!! Thank you!
SOURCE: Janome 5000 screen remeins black
my needle keeps going up and down  after i stop a seam  is it my foot control? if i stomp  hard on foot control the needle stops as  it should
Posted on Sep 16, 2008
bargainbox
  • 1388 Answers
SOURCE: We need a repair manual
Janome stopped supplying the Back Light for the MC8000 some years ago. An enterprising fellow in Sydney, Australia does have some that he had manufactured especially to replace the Janome version.
What region do you live ?
I can give you the contact details and you can see about international freight etc. if applicable
As far as the Service Manual, they are given to Janome Trained Technicians and you will find it very difficult to persuade one to let you have a copy, it is their livelihood afterall.
www.bargainbox.com.au
Posted on Nov 28, 2008
bargainbox
  • 1388 Answers
SOURCE: Janome 6600p: E1 error
Hi
Direct from the Janome workbook E3 error relates to:
"Stepping motor for tension release (MC6500P & MC6600P only)"
Ensure there is no lint or thread trapped between the discs of the top tension unit.........try "flossing" where thread goes down thru tension unit with a scrap of clean fabric.
It may also be the mechanism that releases tension when the presser foot is raised....it is a sensor and may be out of alignment...not really an easy home fix.
Let me know how you get on, just remind me of the issue as I respond to many.
Bargain Box
Posted on Jan 02, 2010
  • 161 Answers
SOURCE: please, i need janome 634D serger manual thank
you could buy from sewingmanuals.com
Posted on Sep 14, 2010
Tally Girl
  • 1133 Answers
SOURCE: My footup and footdown button
Turn the machine off first and unplug.
If you've got a manual, look up the page for trouble shooting, this error message may be listed iwth a solution. I'd also suggest that you remove and clean out the bobbin holder. This is the little black piece you put the bobbin into. It has possibly dislodged if you've had a jam up. You will need to unscrew the two screws holding the needle plate down, take out the needle and pressure foot to give yourself some room too. Put the bobbin holder back into position lining up the red markings on the holder and the stopper, your manual should show images of this.
Once its all back together, turn on and hopefully it will reset to normal mode.
If you've done all this and the error message won't stop showing, then yes, you'll need to take it in for a service.
Posted on Jul 21, 2011
Janome dks 100 se - it keeps beeping when I press the foot pedal and I have to do this several times before it starts sewing. It doesn't beep when using the stop/start button and is sewing fine
Same machine and model and same problem. It’s really irritating. It’s not the bobbin as the screen flashes worth the foot pedal. I’ll look at the tension but given how often it beeps and on so many different projects with different thread and tension it seems to be a fault of some kind... searching for a fix...
Sep 13, 2017 | Janome Sewing Machines
Kenmore 385.19233 shows E1 and I can not find it in the manual. What does it mean It is a sewing machine
I have found that most often the E1 code means the presser foot is not down or not all the way down (a walking foot attachment can keep it from dropping all the way). I didn't find any error codes in the Kenmore manual either. I have several Brother machines that are quite similar in design and since Kenmore doesn't actually make anything, it is probably made by Brother or Janome.
Feb 03, 2017 | Kenmore Sewing Machines
My Janome Harmony 8048 continues to loose its memory which causes an E1 error. What can be done?
Internet research shows this may be a problem that needs to be addressed by a technician. Take it for service.
Questions Answers for janome e1 error
Jun 01, 2016 | Janome Sewing Machines
Bobbin winder is engaged and shows up on screen correctly, but sewing mode is still engaged and bobbin winding keeps stopping.
check the drive knob on the end of the machine
it should be loose when winding a bobbin
if it is tight or seized then that will drive the needle
Sep 20, 2015 | Janome Sewing Machines
Hi Mr. Janome expert, My Janome Memory Craft 4900QC is showing error message E1.Unfortunately I lost the manual to identify the solution to this problem. Could you mind telling what this error means...
E1 means it out of order--something in the electronics is mess up--it needs to be serviced
by a service tech with the tools to check the electronics of the machine
Sep 13, 2011 | Janome Memory Craft 4900QC Mechanical...
Janome E1 error
If a warrantee job, it will be no charge.
Motor in Australia is $149-00.....plus installation charge.
You could phone or email Janome HQ or another dealer in your country and ask for an explaination of the E1 error to satisfy yourself of what is the likely cause, and a quote to fix it.
Aug 21, 2009 | Janome Memory Craft 5700
Hi
Bargain Box
Oct 08, 2008 | Janome Sewing Machines
Jul 05, 2008 | Janome Sewing Machines
Sewing Machines Logo
96 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
