Question about Intermatic Inc. ST01C Digital In-Wall Timer
Suddenly the timer is not turning on the lights. The screen on the timer says "SOU". ????
Here is link to product manual at Intermatic. Manual shows troubleshooting, but doesn't show "SOU"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/st01c.aspx
ST01C works on a 3-way circuit > If another switch is involved, or if switch or timer are not grounded properly, it might affect timer. Troubleshoot says disconnect red wire from 3-way circuit, and see if problem continues, and then suggests replacing timer.
Manual says if CR2 batteries are weak, then BATT shows on screen. Also says weak batteries will cause circuit not to work.
Check the CR2 batteries: Timer holds programming while you replace batteries and clean terminals.
ST01C programmable timer works on circuits up to 100 feet >> I assume because it's battery operated >> electrical interference affects the circuit because troubleshoot lists 'buried wire' as cause of failure. I guess nearby electrical devices could affect performance of timer.
Timer is rated for 15 amps which means practical maximum of 12 amps >>> so 120 volts x 12 A = 1440 watts max or 14-100 watt bulbs >> if you are running more watts, or running close to maximum, or if timer gets warm during operation, this would shorten lifespan simply by heat affecting the circuit.
Interesting that the EI600, EJ500 & ST01C battery-operated timers each has troubleshoot section in manual >>> implying these timers are problematic. ST01C has limited 1 year warranty. EI600 has limited 5 year warranty.
ST01C has 40 on-off programs per week.
If 7 on-off events per week can do the job, you can switch to the EI500 [click on EI500 to access manual]
http://www.intermatic.com/products/timers/in-wall%20timers/digital%207-day%20time%20switches.aspx
>>> the manual shows no troubleshooting section. The EI500 requires connection to neutral or white wire, since the timer runs on electricity instead of battery
[you can use ground wire instead of neutral]
http://waterheatertimer.org/Wiretimer.html
You can compare different types of programmable wall timers:
http://waterheatertimer.org/Programmable.html
Posted on Sep 13, 2010
What do nor, cen, and sou stand for in timer program? This is a Woods digital timer
north, central, and south. The significance depends upon the application.
Nov 02, 2016 | Woods Hardware & Accessories
I have sony Bravia KLV -32V300A suddenly shut-off while I am watching power indicator went off and standby red light blinking 5 times then after 2 seconds off then red light blinks again 5 times and so...
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Mar 09, 2011 | Sony Televison & Video
How do i change or turn off the keypad tone on my samsung GT S8500 mobile phone?
Go to phone profiles, click red arrows on right of screen by Normal profile. Screen shows Normal Call alert type, Melody etc. It top left hand corner Incomi and a down arrow click on the arrow - choose Phon sou and keypad tone appears and you can switch off from there.
Aug 07, 2010 | Samsung Cell Phones
Sony tv suddenly turned off with the timer light blinking ,and it cannot be turned on again
How many tomes is the timer blinking? It should blink a certain number of blinks pause briefly then repeat the process.Thats an error code
Nov 23, 2009 | Sony KP-51WS500 51" Rear Projection...
Screen will begin turning blue, then go black and standby timer light blinks 8x in sequence. I can repower and screen will come back on temporarily. Tv may work for days then suddenly start doing again....
hello ,Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
shaun
Nov 10, 2009 | Sony KP-51WS500 51" Rear Projection...
Standby light blinks and tv won't turn on
Four blinks = No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Dec 27, 2008 | Televison & Video
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Intermatic Inc. ST01C Digital In-Wall Timer Logo
400 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
