Question about Refrigerators
My refrigirator has not working properly, the colling system does not working properly. where do i complain????
  • Refrigerators Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Call the manufacturer directly at there customer service number..
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
There is problem with our kenmore refrigirator the freezer is working but the refrigirator is not working. the refrigirator is not cold enogh it is going to 60 degree
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Kenmore Refrigerators
My air is not running correct.. blowing hot air out.. what can we do to fix this problem
hi
this may be because following reasons.
1. you might have kept the temperature selection switch in heater please check it.
2.there may be leak in the AC line which might have drained the refrigirant so no cooling effect.check the line for leakage.
3.the refrigirant used may be less which doesnt give much cooling effect.
4.the cooling fan which cools the refrigirant may not working or speed is reduced which may reduces the heat transfer rate
if my answer were useful to you please vote me.
Jul 11, 2010 | 2003 Hyundai Santa Fe
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
Cooling fans dont work
check for cooling fan relays
Dec 26, 2009 | 2002 Chevrolet Impala
My ac was working and then just stopped.
NO that means that the system is working properly.The switch is a low pressure swtich and it is in the open position because the system needs a charge, if you bypass the switch you run the risk of burning out your A/C compressor. The refrigirant is also a lubricant.
Sep 24, 2009 | 2003 Honda Odyssey
Freezer is cold but the fridge is not?
You have to correct setting on temp that you want in the refrigerator right
Aug 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working and freezer temp only -4
it seems tht the problem is with the compressor of the refrigerator.
sometimes it happens that the "gas" in the compressor leakes off and ,tht gas is responsibale for the colling of the refrigerator.
so,either you can go for refilling of gas
or u can buy new compresssor of same rating as refregerator have.
my personla recommendation is to go for new compressor bcoz most of the time it happened to me that the customes complain abt the temperatures and some complain abt the leakage od gas again.
so,best option is to go for new compressor.
in case u hav any problem furthur just write me on my email -anshlittle011@gmail.com
Jul 06, 2009 | Liebherr European Right Hinge Fully...
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
Open Questions:
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
