Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Flashing error message "6ae lo" on the thermostat.
2 Suggested Answers
SOURCE: 6AE Lo
6AE Lo is probably 'bAt Lo'. Batteries are low and need to be replaced.  It looks like 6AE Lo because of the digital readout (b looks like 6).
http://www.espenergy.com/faq_honeywell_thermostat.htm
Model number shouldn't change what the readout means.
Posted on Dec 11, 2009
Our Honeywell programmable thermostat T8132A 1049 1 controls a Gasglo gas central heater. An old battery leaked onto one battery contact; even with new batteries the BATT LO message came up. After...
The T8132A thermstat requires 2 AA alkaline batteries for operation as the T8131 uses the 24VAC souce transformer with battery back up. If new batteries did not fix the problem follow product user manual to reset and program the thermostat. This should clear any errors or problems. If the problem persists then replace the thermostat. If you do not feel confident you can accomplish the task then you should call a licensed HVAC technician to troubleshoot the issue as the wrong settings could potentially cause permanent damage to your system.
Link:
http://s3.pexsupply.com/manuals/1287594709924/40775_PROD_FILE.pdf
May 09, 2011 | Honeywell Programmable Thermostat Heater
Bae lo This is the message my electric Honeywell programable thermostat is flashing. It's still working. What's that mean? Thanks.
Try with this site:
Honeywell thermostat website: http://yourhome.honeywell.com/home/Applications/SmartSearchResults.aspx?searchkey=thermostatfor heating
Dec 12, 2010 | Heating & Cooling
My beutler 800 said lo bat we replaced them and still reads bat lo
The other "solution" posted here is not a solution. According to this web site: http://www.espenergy.com/faq_honeywell_thermostat.htm
First, replace the batteries with a new set of AA alkaline batteries. If you insert the new batteries within 20 to 30 seconds of removing the old ones, you will not have to reprogram the thermostat. If the bAt Lo indication does not clear itself once new batteries are placed in the device install the batteries backward for 5 seconds, take them out, and reinstall correctly.
So I tried it... put the batteries in backwards. It completely reset the thermostat so I had to reprogram it (which was easy enough). One thing I did that the instructions did not specify. After I removed the batteries, I let it go completely blank before installing them backwards. Then I waited 5 seconds, pulled em out and put them back in correctly and eventually it started flashing indicating it needed to be programmed. HINT: Don't forget to set the current time!
Dec 04, 2010 | Honeywell Programmable Thermostat Heater
Flashing LO
"LO" means a "Limit string open error" has occurred. See the owners manual for the many causes and possible solutions. Owners manual found here. http://www.haywardnet.com/products/Manuals/pdfs/Manual225.pdf
Apr 08, 2010 | Hayward 350K BTU H SERIES HEATER DRAFT...
Bat lo flashing periodically
You need to change batteries. The bat lo light flashes when you have about 10% battery life left. Rus
Dec 05, 2009 | Honeywell CT3200 5-2 Day Electronic...
6AE Lo
Oct 14, 2009 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
773 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
