Question about Kitchen Ranges
There is hardly any water flow from the faucet in the refrigerator door. A re light at the top of the refrigerator side sys the water filter is plugged. Where is the filter and how do I clean it? Thanks.
  • 905 Answers
Without knowing the manufacturer and model of your fridge, it will be impossible to tell you exactly.
Some manufacturers have the filter installed on the back side of the fridge, some will have it behind an access panel. Others will have the filter located at the bottom kick panel on the front of the fridge. Others will have it located in the refrigerator compartment, behind an access panel.
If you post the make and model, perhaps I can find the user manual for you, maybe a source for filters as well. Filters are typically replaced, and not cleaned.
Posted on Sep 11, 2010
In door water dispenser of ED25QF will not dispense water. New filter, cannot detect kink in supply line, pump does not sound, still making ice, light in door works, dispenses/crushes ice. What is the...
The pump motor on the dispensing water is the problem. Pump motor problem is cause by no voltage power to motor, burnt motor winding, switch faucet on dispensing water, water supply line has jam, check it if you can if not, call a refrigerator service technician to do the job.
I hope I help you with your problem. Thanks!
Jun 11, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Waterdispenser very slow flow
Good Afternoon, Jayslyrmn:
Look at the tap on your water faucets. If there is a mineral buildup there, white and green crusting, the same thing is happening to your water dispenser, and the ice won't taste too good either.
Check your on-board water filter. You can find a replacement here:
http://www.repairclinic.com/Kitchenaid-Refrigerator-Filter-Parts
It's literally a snap fix.
Enjoy your ice tea!
Chr
Apr 16, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Kitchenaide fridge icemaker is not working at all.
Check the water flow at the door.
If the water flows slowly, then you have a clogged water filter.
The filter is either outside below the doors, or in the upper right side of the refrigerator side.
Good Luck!
Jan 03, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Water filter light won't reset itself
look closely at the panel it will state which buttond to hold for 3 secs to "reset " filter light
Jan 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is not coming out from Samsung RS2630WW Side by Side Refrigerator. I realized there was no filter. After installing filter I reseted and light when off, but water still not running
the water resevour is proberbly frozen inside of the refrigerator. Open the door and remove the bins in the refrigerator and you will see a resevour tank. take a hair drier and heaqt up the tubing that comes out of it until the water flows again.
Jan 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
No water from door outlet
Hi. Thanks For The Question. I Would Check The Water Valve. Disconnect The Water Line From The Valve ,Leaving The Water On. Now Push The Water Button. If Water Flows You Have A Blockage. If Water Does Not Flow. Replace The Valve .Thanks The Appliance doc
Oct 02, 2008 | Maytag MSD2656G Side by Side Refrigerator
Icemaker won't fill with water
If you would like a repair manual for your refrigerator, you can get one here. These are helpful to have in case you have other issues with the fridge.
Thanks
Sep 29, 2008 | Samsung RS2630WW Side by Side Refrigerator
Power fail light, water and air filter warning light, and crushed ice dispenser light stay on all the time.
Your stated water pressure is abnormally high; well systems supply 30-60 pounds of pressure and municipal systems are *supposed* to be around 60# since most plumbing (faucets, showerheads) is designed around that point.
If your pressure has been measured at that level, more than your refrigerator is at risk of failure.
Jul 19, 2008 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Slow water flow
dadcanfix. There are two possibilities here. One could be the water valve itself, clogged or not seating or opening properly. The second would be the water tank on the refrigerator side, partially frozen. I believe they have a kit now with coiled tubing that replaces that tank because of the trouble they had with it. Remove the refer drawers and take a hair dryer and go over the tank lightly. See if that improves the water flow. Catriver..post back.
Mar 20, 2007 | Frigidaire FRT15G4B Top Freezer...
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
