Question about Hotpoint HSS25GFP Side by Side Refrigerator
Just purchased fridge. How long should it take to get your first tray of ice to drop?
  • 4,793 Answers
I always suggest that you allow 24 hours to let the unit settle down,and then when it does produce ice throw away the first couple of gallons...
Posted on Sep 11, 2010
Ice maker is not dropping ice
there are 2 things that could be problem, 1 is a heater element that heats the bottom of frozen cubes slightly to allow the cubes to be pushed out into the tray by plastic fingers under the cubes and controlled by a motor. best bet would be to get model number of fridge and/or ice maker and look for direct replacement online. There is a company out of Chicago that offers replacements for lots of models. Sorry I dont have their name, but google the results for ice maker for your make/model fridge.
Jan 28, 2013 | Refrigerators
Where to purchase the ice cube tray for toshiba
There are many ice cube trays out there, I have never heard of one specific to a fridge. I would suggest replacing it with any generic ice cube tray From and department store Good luck
Sep 07, 2012 | Refrigerators
I PURCHASED A WHIRLPOOL GS5VHAXWY FRIDGE AND THE ICE IS NOT COMING OUT OF THE DISPENSOR WHAT IS WRONG WITH THE ITEM
first thing to check is that you have water going on the inside of the ice maker tray simply stick your finger inside and see if there is water if there is no water you would then look at the water valve or the line in the back of your fridge if there is water or rather there is ice inside the tray you would want to remove the ice maker and run the tray under hot water then reinstall to test if this does not work then replace the ice maker hope this helps
Jul 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My LRSC26923TT side by side fridge/freezer has stopped making ice. It still dispenses water but it would not dump the last tray produced. I removed the cubes from the tray by hand, emptied the freezer, and...
Unfortunately, Ice Makers are notoriously unreliable and most require more expertise than a handyman possesses. Most require replacement of one of the 4 main parts (usually not generic): drive motor, water solenoid, heating release element or bin full ice arm control switch.
A Certified Technician should be able to diagnose the problem and suggest a repair or replacement.
Apr 22, 2017 | LG Refrigerators
Icemaker tuns but ice does not drop out
OK the reason the Ice isn't dropping is that the element under the icecube tray isn't working. You'll need a new Ice tray with element I'd be guessing, but see how you can buy it. Some models you need a whole new ice maker. Cheers
May 21, 2009 | Samsung RM255LASH Side by Side...
Ice-maker problem
if the water runs constantly when you turn the water on its your valve but if it does it periodacally it probably your icemaker
Apr 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice not emtying from tray
Sounds is if the ice mold heater is not functioning. This heater warms the bottom of the ice mold just enough to melt the ice and let it drop out. Usually not a repairable item. Replace ice maker assembly - if you're not comfortable doing it yourself, call a repair company.
Mar 20, 2009 | Samsung Refrigerators
Regrigerator shows error code 1F
Hello tr-6
Welcome
You Wrote,
LFX25960ST LG FRENCH DOOR REFRIGERATOR DATE OF PURCHASE 7-7-07 DELIVERED 7-13-07 ICE MAKER REPLACED ABOUT THIS TIME LAST YEAR AFTER TWO MONTH WAIT. NOT PLEASED WITH PERFORMANCE OR SERVICE TO DATE. REQUEST THIS PROBLEM BE COVERED BY WARRANTY.
Below is the service manual And the explanation for your error.
Thank You for using our site.
Huuum
Please remember to leave a solved rating.
Error Detection Category
ERROR CODE : IF
Abnormality of
BLDC FAN Motor
for Ice Making
Error Generation Factors
It is caused when F/B
signal isn’t over 115
seconds during BLDC
FAN motor operating
Remark
Poor BLDC Motor
connection, DRIVE IC, and
TR
Resource reference located here:
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Huuum
Oct 12, 2008 | LG LFX25960ST Stainless Steel French Door...
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Jun 14, 2007 | LG LSC26905TT Side by Side Refrigerator
Ice Maker No Longer Works - Water Works fine
Not sure if this will work for you - I had a similar problem with a Kenmore fridge. I removed the ice tray and found a piece of ice stuck where the ice is made and dropped into the tray. Once I clear this obstruction, the ice maker worked again. Also, check for the mechanism that indicates that the ice tray is full. This may be jammed or malfunctionin.
May 09, 2007 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
