Question about Intel Motherboard
Installed gigabit MB new power supply, all new parts and only get flashing lights on the optical drive on boot up any ideas what i could be doing wrong ?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
1. Check whether two power connectors are connected (one is 20 pin and the other 4 pin)
2. Remove all FRONT USB, Audio, HDD, CDRom and other connections on motherboard, except the power button connection now turn on.
3. If still does not, instead of Power button use reset button connection for Power button and try.
4. Check whether proper memory supporting type is installed in proper direction, try putting in another slot.
5. Change the SMPS eventhough it may be powering on.
6. Check the Motherboard by keeping it externally taking precautions.
Posted on Sep 11, 2010
My pc is not displaying, keyboard not coming on, sytem fan is running fast and the mouse is on please help me to fixya this. My email is aamos@webmail.co.za.
Sounds like you have a hardware problem. Try to isolate the problem first.
just retain the connection for power supply for the motherboard. disconnect the hard drive, optical drives connectors power / power supply Try to detach the memory and plug it back in. Do this with your video card as well. if you have other cards installed on your slot remove them first. just retain the video card. The idea is to just enable the basic parts to make your computer boot up (not up to the operating system since we remove the hard drives)
Sep 10, 2011 | Intel Computers & Internet
Gateway 503gr has no power, the standby light flashes green when I remove power. Tried new PS and the standby LED stays lit. I then tried both new and old PS disconnected from board and shorted...
Disconnect everything from the motherboard except the power supply connections and cpu fan. Install one stick of RAM and connect your monitor. Then try starting up. See if you get any BIOS boot messages. This will tell you that the board and processor are okay.
With what you say you've tried already, I'm thinking you might have a bad processor. Most every other problem would result in some kind of error like POST beep codes or messages on screen. If the system still doesn't boot with the bare minimum parts installed, replace the processor.
Mar 02, 2010 | Gateway 503GR PC Desktop
Computer does not boot, blue on light lites up but
Now when you say blue power light, what are the rest of the lights doing, does the hard drive light flash, does the fans turn on, does the hard drive make it's spinning noise, if so you may just have a bad LCD inverter which is very common and about a 40$ part. you can test this by trying to hook the laptop up to an external monitor and see what happens.
Sep 24, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Flashing ? tried everything then installed new HD however now the macbook keeps ejecting the install CD before anything happens onscreen cant hear fan and superdrive making slightly grating noises . any...
Try the following: 1. Reset the powermanager by pulling the battery and holding down the power switch for 5 seconds than wait a few more seconds reinstall the battery and plug in your power supply. Push the start button. You can watch the light on the magsafe adapter to confirm that the power manager resets. 2.If you still do not boot to the CD try booting while holding down the C or the option key. 3.If you still do not boot up and have a second mac: try booting into target disc mode connect to the other mac with a firewire cable and install your software on the hard drive remotely. Good luck
Sep 03, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have a HP M 7160 that will not turn on. There
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen. The PC may not boot to windows, but it Does post at this point, and with that the problem is resolved. If windows does not load, then you have a new problem. Best dealt with asking a new question.
Brian
Jun 20, 2009 | Bestec (ATX100-5) (ATX1005B) Power Supply
Reboot and select proper boot device or insert boot media in...
Ok..try this. Disable the flash screen and quick boot options in bios. What might be happening is the prompt to boot from CD isn't being displayed due to one of those two options.
Apr 30, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Replacement Motherboard (ASUS) P4S533
try using a bare system only means motherboard, psu, processor, ram then connect a speaker, does it make any sound ?
Oct 17, 2008 | ASUS A7S8X-MX Motherboard
Power supply runs, but no bios or boot
yes it sounds as the the cmos bios chip is damaged, if theres no bios showing, you will have to replace the mobo.
Sep 03, 2008 | Dell XPS 200 PC Desktop
Pc wont turn on
removed hard drive, floppys , extra memory all pc cards
everything you can and try it again
Jan 18, 2008 | Antec TruePower Trio 550 (TP3550) 550-Watt...
No power to 12 volt, Hard drive, or Disk drives.
Retrace your steps there may be a loose wire(s). Have you checked and rechecked your pinouts? maybe one of the wires is backwards. Hate when that happens. It could be bad out of box. Try unhooking everything then one by one rehook your components. Maybe by terrible coinsidence a part fried and is preventing the machine from booting. Make sure your CPU fan is plugged in. I am installing a new motherboard now and those are the pitfalls I keep track of.
Mar 08, 2007 | Enermax (by Coolergiant) ELT400AWT Liberty...
Intel Motherboard Logo
44 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
