Question about Jenn-Air 21.6 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Seems the freezer door was not completely closed. Ice started ot melt and then form icicles! Well we closed the freezer the next morning. Now the ice maker and water dispensor are not working. In addition, the bottom crisper was frozen (set at warmest setting). Will this repair itself or do I have to manually defrost the entire fridge? I would think the water tank was frozen and would defrost, but why would the ice maker stop working? Thanks!
  • 4,793 Answers
When you closed the door, the freezer froze all the condensation/melting ice,hence the icemaker freezing.
the best solution is a TOTAL defrost/clean out,then dry out.DO NOT USE HOT WATER/SCRAPERS,let it defrost naturally or use car de-icer.wipe out with bicarb to keep fresh.and then restart as new.
Posted on Sep 11, 2010
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
GE Refrigerator, ice melts in ice bin, Excessive heat on refrigerator side
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 09, 2012 | GE Refrigerators
I have icicles all over my freezer. They started on the door under the ice maker. It is making ice but it won't come out because it the turning thing can't turn because there is solid ice in the bottom of...
Your icemaker is surely at fault. Shut the water off at the valve, turn off the icemaker, and defrost again. Does it happen again? If not, check your icemaker assembly for leaks or replace the water inlet valve if necessary. Good luck.
Apr 24, 2011 | Refrigerators
GE refrigerator, ice melts in ice bin
Since your refrig is cooling , I would replace the # 4 AND # 5 thermistors . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Nov 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
Icicles forming from melting ice from ice maker
hi this might help you:
*make sure that the seal indeed still seal well enough...
*the older the fridge the more common this is
i don't really know much about this, but just check that it's cold enough inside like check if it changes when you change it from eg 4 to 7, and that the sealing is fine, and that your door is lined out good, also important that last thing offcourse, cause if it seems to shut good, but the seals arent in the right position compared to the other side (the 'fridge-walls' :p) they won't seal ofcourse...
I hope this is useful, and greets.
Oct 20, 2009 | Refrigerators
PCG23N ice cube dispenser area problem
This is probably due to the door flap in the ice chute not closing tightly. There is a solenoid that operates the door that could have stopped working. Can you hear it? The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Aug 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Melting
ok check the door gaskets they must be toushing forming a compleate seal nothing else is acceptible also there is a possibilty that your ice maker heater is stuck in the on position.also these units are known for a having a bad control boared in the back
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
My GE Profile makes ice but then the ice cubes melt!
repl main board and make sure your out let is properly wired and grounded those main boards are sensitive when not grounded
Oct 29, 2008 | GE Profile PSW26P Stainless Steel Side by...
Freezer defrost all. RS2556
The most likely is that the door was not closed properly, this is very common on this model, what happens is that the door closes against the freezer contens and therefore appears closed, this allows warm air into the unit which starts to melt the ice, if this should happen again it is a good idea to completely defrost overnight with the doors open and then re start the next morning as ice often builds up behind the rear panel. Regards Advisor
Jul 04, 2007 | Samsung RS2556 Side by Side Refrigerator
Jenn-Air 21.6 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
145 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
