SOURCE: TV suddenly shuts off and lamp light comes on, but lamp is OK
did you reset the lamp timer? just a guess
SOURCE: TV won't come on
Im not at home right now so I can not get the exact part number but you need the powersupply for this set. There are numerous bad capacitors on this board and you might have a blown main on here. Replacing this will repair your set back to working condition.
Josh
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
SOURCE: 52" dlp
YOU NEED TO RESET THE TV. USE A PAPER CLIP TO HOLD DOWN THE BUTTON, AFTER THE LIGHT FLASHES FOR ABOUT ONE MINUTE YOU SHOULD BE ABLE TO TURN ON THE TV.
