Question about Xerox WorkCentre XD100 All-In-One Laser Printer
When we turn machine on, it seems to be stuck in the warm-up phase. It won't allow you to copy but just incessantly does a little back-and-forth of the light bar thingy. da-da, da-da, da-da, da-da. or something like that. Once in awhile, if we leave the machine off for hours, it will start up and run fine, but if we leave it on after making copies, then when we come back to use it again later, it does the same thing. Help!
  • 1,110 Answers
The light bar bumping back and forth means the machine is trying to reference the exposure lamp intensity. Usually this is solved by cleaning the white reference strip which is under the plastic edge guide. The guide is the part with the document size numbers on it. Removing this piece and cleaning the white strip under it will usually solve this problem.
Good Luck and Thank You for using Fixya.
Posted on Sep 11, 2010
The hand wheel is stuck and won't move. machine makes a vibration noise
try working it back and forth it might jst be stuck a little but vibrating might mean you are putting it out of time too.
Jan 19, 2015 | Brother XR9000 Sewing Machine
How can I get my key stuck out of the ignition?
sometimes if the steering wheel is turned all the way to one side it puts pressure on the ignition key switch and won`t allow the key to turn all the way back to remove. another thing could be if the key switch tumblers/key are worn will cause this as well. the one thing to try is to move the steering wheel a little back and forth while continuing to turn the key back and forth it may release. if not then you will have to take it a shop to have it removed.
Jul 24, 2014 | 2007 Kia Spectra LX Sedan
Spool won't turn
are the rollers tightened enough, also maybe the wire is jammed in gun.
Feb 02, 2013 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Epson projector is stuck in start up mode
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Dec 24, 2012 | Epson ELPLP69 - V13H010L69 Projector...
Hi, we have received our Gaggia Brera today and it won't prime. We followed all the instructions in the manual and the red triagnle keeps blinking. We're quite desperate to make it work... Any...
Hello, are you turning to the selection knob back to its central position? once you do this the and the unit warms up the triangle should disappear
The icons displayed blink slowly to
show that the machine is warming
up.
When warm-up is complete,
the machine performs a rinse
cycle of the internal circuits.
During this phase, the icons displayed
will blink in sequence.
• When the operations described above
are completed, the icons on the display
will illuminate.
The display will appear as
shown to the side. The displayed
aroma is the factory setting
when the machine is switch on for
the fi rst time, or it is the same as the
aroma that was selected for the last
brewed coff ee.
The machine is then ready to brew
beverages if you have any further questions or the triangle does not go away please message me back for further diagnosis Thank you
Rick
Nov 05, 2011 | Gaggia Brera Coffee Maker
Need to release left margin, it's stuck in the middle and won't allow me to move the margin any farther to the left.
Turn the machine off move the carrier back & forth by hand and see if it will go all the way to both ends. If it doesn't look for debris in it's path. If it moves put some WD40 on the silver shaft that the carrier slides on. Put some WD40 on the bfront and rear carrier motot bearings, the front one can be reached from inside the T/W the rear one will require snaking the straw thru the case.
DickyO
Sep 29, 2011 | Lexmark Wheelwriter 15 Series II...
Key is stuck in ignition. Depressing the "unlock"
Somtimes you need to turn the steering wheel a little to allow the lock to engage.
Try depress the unlock button while moving the steering back and forth a little. Try a lot..
If not work, drape a scarf or towel over steering column to hide key in ignition, and use spare key to open door lock. You do have spare key?
Check your insurance, you may have lock smith lock out coverage.
Good luck.
Feb 27, 2011 | 1990 Nissan Maxima
Shuts down during warm up
the fuser unit is not warming up, so the machine shut down
Mar 21, 2009 | Xerox Office Equipment & Supplies
Hp psc 2110 copy problem stuck warming up & scanner bar get stuck
The scanner carret belt might be too loose, so the printer cannot pass through the self-test. Try tightening it a little bit. Also you have to either repair the nobs or solder it.
Feb 14, 2009 | HP PSC 2110 All-In-One InkJet Printer
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
195 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
