Question about Rival 8806 6 Quart Ice Cream Maker
The motor spins the wrong direction allowing the canister to pop out of the holder notches
I need a canister for my ice cream maker from cooks essentials, model number 95100 Could you help, please?
wrong site fixya doesnt sell products --try online search or manufacturers site
Jul 25, 2017 | Ice Cream Makers
I have lost the clear Canister lid and cap. Can I get a replacement
I have found that 90% of canister Ice cream makers are modeled the same, I have had a Back to Basics, Rival and West Bend Ice cream makers and the lids are interchangeable.
A lot of companies don't make replacement parts so I usually go with the West Bend lid. The first thing you will want to do if find the brand on your Ice Cream maker (usually found on the motor/top) and see if the manufacture does make replacement parts for your machine. If they do not have parts available I would try the West Bend Ice Cream maker lid U66-2, like i said it is a pretty standard size and will fit most Ice Cream Canisters.
Here is a link to West Bends part page: IC10885 Ice Cream Maker
The lid is very inexpensive so even if it doesn't fit your not throwing away a lot of money.
-Colleen @ Mending Shed
Apr 19, 2015 | Ice Cream Makers
Where can we acquire a new cover?
Unfortunately Rival doesn't make replacement parts available for their appliances. You can contact them directly at Sites rival products Site However I haven't ever been able to get replacement parts through them.
I have found the 90% of canister style Ice Cream makers have the same size lids. In the past I have purchase West Bends Ice Cream maker lid and it fits perfectly on both my Rival ice cream maker as well as my Back to Basics model.
Here is a link to the parts on West Bends site:
The lids is part number U66-2, and is only a couple of dollars from West Bend.
Apr 14, 2015 | Rival Ice Cream Makers
I cant get the bobbin holder back into the prolectrix 8 machine
Below is a picture of what i think your machine looks like ...
the pink outer case is inserted first with the 'opening' at the back.
The black inner case has a notch shown in red this lines up with the notch on the pink case shown in blue.... i sthis what you havea4d335d3-67ce-4e4d-b0f7-f0ee5104179e.jpg
Dec 12, 2013 | Ice Cream Makers
I CANNOT REMOVE THE DASHER TO DISASSEMBLE FOR CLEANING. THE MANUAL FOR THIS SUNBEAM ICE SHAVER SAYS TO TURN THE DASHER COUNTER CLOCKWISE UNTIL IT UNSCREWS. FROM THE UPPER HOUSING. NO WAY IT JUST KEEPS...
Laura at ifixit posted a response 4 days ago that helped me solve this problem. ifixit(dot)com/Wiki/Sunbeam_Snow_Cone_Maker_Troubleshooting
I was unable to remove that dasher following the directions. When I turned the dasher counter clockwise it just spun and spun the motor. To fix this I removed the four screws at the bottom of the machine (hidden under gray rubber foot pieces) Removed the white base and held the clear circle motor wheel steady while rotating the dasher counter clockwise -it released in just a few spins. After reassembling the product the dasher removes per manufactures directions.
Hope others can get there machine fixed. I called Rival with this fix as well in hopes others could clean their machine. Thanks again to Laura at ifixit.com!
Aug 10, 2013 | Sunbeam Slushies Snow Cone Maker Snowcone...
Does the dasher move on the ice cream maker or just the canister?
The dasher rotates, driven by the motor. The canister isn't supposed to move, but sometimes will depending on how thick the ice cream mixture gets. Presumably, if the ice cream were to freeze hard enough, the dasher would find it harder and harder to turn, until eventually the entire canister, with the dasher embedded in the ice cream, would start to rotate in the ice.
Mar 04, 2011 | Nostalgia Electrics ICMP-400BLUE Ice Cream...
Machine is model 750-27can you help me? runs for only about 5seconds not long enough to make ice cream
Welcome to FixYa
An electric ice-cream maker is a tabletop appliance for mixing and freezing ice cream at home. A small electric motor drives gears that turn the canister filled with the ingredients for ice cream. The canister is surrounded with ice and rock salt to freeze the contents. Alternately, a hand crank on top replaces the motor.
Although durable, ice-cream makers can require a few repairs. A common problem is damage to motors or gears from mixing too large batches of ice cream or from neglecting a jammed mixing paddle. The electrical cord can fail and motor bearings can dry out.
Read Following ...
  • Use your cylinder bowl correctly. If the cylinder isn't handled properly, your ice cream won't set. Make sure it is dried completely after washing so ice doesn't form on the walls, make sure to leave it in the freezer overnight before making ice cream and don't leave the bowl out at room temperature before using.
  • Check your freezer door. If it isn't sealed properly, or if it's constantly being opened during the freezing process, your ice cream can't set properly.
  • Handle the ingredients correctly. Don't let the ingredients warm and don't overfill the bowl. Check the manufacturers recommendations for the maximum bowl capacity.
  • Clean and dry your machine thoroughly. Use a damp cloth on the motor assembly; never immerse. Make sure to wash the lid, blade and cylinder according to directions and make sure the cylinder is absolutely dry before freezing.
  • Contact the manufacturer's support site only after you have exhausted your options. They may walk you back through the steps you've already taken, but at best your problem will get fixed far more quickly because you eliminated the easy problems in advance.
I hope this Instruction guide will help you Click here Read carefully Instructions[Specifically Page27, 29,31]
OR click here
Just Check this Link too
Thanks for Contacting FixYa...
Jun 27, 2010 | Taylor 632-27 Ice Cream Maker
OUr rival 8550-x 5 quart wooden electric ice cream maker doesn't turn the blade in the canister. The motor is running but the blade doesn't turn in the canister.
take it apart and find the striped gear the motor actualy turns at 2000 rpm and has a reduction unint inside
eithor the gear is striped or the grub screw fell out of the drive gear could also be a drift or sheer pin on the main shaft
Aug 03, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
Deni Ice Cream Maker Manual
I don't have a flatbed scanner to scan it, but here are the operating instructions (at least for the 5201).
1. Place canister in freezer for 8 hours (must be frozen solid-so that you can't hear liquid in canister sloshing around)
2. Prepare your ingredients ahead, and chill them for best results.
3. Take canister out of freezer and place on motor base. Use canister immediately after removing from freezer, as it will begin to thaw once placed at room temp.
4. Place the paddle inside container. Be sure the tould side of the paddle faces up.
5. Lock the lid (the clear plastic piece that fits over the container)onto motor base. The tabs on the bottom of the lid should line up with the indentations in the motor base. This ensures that the lid is locked in place. When fitting the lid onto the base, the stir paddle should "fit" into the lid.
6. Turn the On/Off dial to the right (on position).IT IS IMPORTANT THAT YOU TURN THE UNIT ON BEFORE POURING IN THE MIXTURE. THE CANISTER ROTATES WHILE THE STIR PADDLE REMAINS STATIONARY.
7. Slowly pour the mixture in the top opening of the lid. It is at this time that you place the top on the clear-vue lid and leave the machine on for about 5-30 minutes (time varies, depending on the coldness of ingredients and canister, and desired consitency) If making ice cream, your result should be a soft, custard-like ice cream
8. When the frozen dessert is ready, make sure the unit is off. Remove the lid and the mixture from the bowl with a plastic spoon or scoop. NEVER USE METAL INSTRUMENTS IN THE CANISTER.
9. Ice cream will be custard-like. If you prefer hard ice cream, place in freezer in air tight container and allow to set until it reaches your desired hardness. Don't put the ice cream in the canister in your freezer for more than 30 minutes, as the ice cream will freeze solid to the container and possibly damage it.
Hope this helps... If you need something else, let me know. I will try to check back soon.
Apr 14, 2008 | Deni / 5201 / 5202 / 5203 / 5205 Ice Cream...
Rival 8806 6 Quart Ice Cream Maker Logo
Top Rival Ice Cream Makers Experts
Henry  Thomas
Henry Thomas
Dan Webster
Dan Webster
Stan Skaggs
Stan Skaggs
Are you a Rival Ice Cream Maker Expert? Answer questions, earn points and help others
