Question about Boating
Water leaking atbottom moter where it bolts up to midsection 89 johnsongt200 leaking atboatside right
    Problem Solver:
  • 5 Answers
As long as it is pumping good and not running hot, this is not a problem. make sure bolts are tight.
Posted on Sep 30, 2010
1989 Toyota 4x4 22re? 6mm hex bolt missing from thermostat housing, could that cause water to leak into the head?
I do not see how that could possible leak into the head unless you had a crack in the area that the water was leaking. It would at least not be because of the bolt missing.
Mar 23, 2016 | Toyota Cars & Trucks
Leaking water at bottom centre both sides atbottom of base
call a good plumber your wax seal has gone the trip
Apr 13, 2015 | Home
I would like instructions on changing a water pump in 2005 Chevy uplander V6 3900
This is probably the easiest water pump of all vehicles to change.
Water Pump Replacement
Removal Procedure
  1. Drain the cooling system.
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  1. Remove the water pump bolts, pump, and gasket.
  2. Clean the water pump mating surfaces.
Installation Procedure
  1. Install the water pump gasket and pump (1).
Notice: Refer to Fastener Notice in Service Precautions.
  1. Install the water pump bolts.
    • Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolt until snug.
  2. Install the drive belt
  3. Install the water pump pulley bolts.
    • Tighten the bolts to 25 Nm (18 ft. lbs.) .
  1. Fill the cooling system
  2. Inspect for leaks.
Aug 18, 2013 | Cars & Trucks
Water pump
Which engine?
  1. Drain the radiator
91192665
  1. Loosen the water pump pulley bolts.
  2. Remove the serpentine belt.
91192666
  1. Remove the water pump pulley bolts and pulley.
  2. Remove the water pump bolts, pump and gasket.
  3. Clean the water pump mating surfaces.
  1. Install the water pump gasket and pump.
91192667
  1. Install the water pump bolts. Tighten the water pump bolts to 89 inch lbs.
91192668
  • Install the water pump pulley and bolt until snug.
  • Install the serpentine belt.
  • Tighten the water pump pulley bolts. Tighten the water pump pulley bolts to 18 ft. lbs.
  • Fill the cooling system and purge of air.
  • Inspect for leaks.
  • Sep 27, 2012 | 2001 Oldsmobile Alero
    I have a 2002 ford taurus and antifreeze is leaking cant tell from where but it is getting all over my belt and causing smoke could this be a simple hose or a water pump im at a loss
    Hello! It sounds like the water pump is leaking...But first, inspect your hoses and their clamping points...
    if you can observe coolant leaking, running from the center of the rear of the water pump then it's time to replace it see diagram below for bolt torquing sequence...Bolts1-7=18 Ft. Lbs....Bolts 8-12= 89 In. Lbs.
    Guru...........Saailer
    9_25_2011_12_27_31_am.gifACDELCO Part # 252467
    COST $50; RockAuto.com
    Sep 25, 2011 | 2002 Ford Taurus
    How to change the water pump on a 2006 equinox ls
    1. Drain the cooling system until the coolant is below the level of the water pump.
    3. Rotate the drive belt tensioner to release the tension on the drive belt.
    4. Remove the drive belt from the right idler pulley.
    5. Carefully release the drive belt tensioner spring tension.
    6. Remove the water pump pulley bolts.
    7. Remove the water pump pulley.
    8. Remove the water pump bolts.
    9. Remove the water pump.
    10. Remove the water pump gasket.
    11. Clean the water pump mating surfaces.
    To install:
    Fig. Remove the mounting bolts (3) to remove the water pump (1) and gasket (2).
    1. Install the water pump gasket (2).
    2. Install the water pump (1).
    3. Install the water pump bolts (3). Tighten the bolts to 10 Nm (89 inch lbs.).
    4. Install the water pump pulley. Loosely install the pulley bolts.
    5. Insure the drive belt is properly centered on all the pulleys except the right idler puller.
    6. Rotate the drive belt tensioner away from the drive belt.
    7. Install the drive belt to the right idler pulley.
    8. Release the tensioner allowing the drive belt tensioner to come in contact with the drive belt.
    9. Inspect the drive belt to insure the belt is properly centered on all the pulleys.
    10. Tighten the water pump pulley bolts. Tighten the bolts to 25 Nm (18 ft. lbs.).
    11. Fill the cooling system.
    12. Inspect the cooling system for leaks.
    Aug 21, 2011 | 2006 Chevrolet Equinox
    I recently changed the alternador belt on a 2001 chevy metro lsi, afterwards whenever i start the car , there is this rattling noise and when i opened the hood to check , to the left of the alternador...
    Water Pump REMOVAL & INSTALLATION Metro
    1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
    2. Drain the cooling system.
    3. Remove or disconnect the following:
      • Negative battery cable
      • Air cleaner
      • A/C compressor suction pipe bracket, if equipped
      • Loosen the water pump pulley bolts. Do not remove them at this time
      • Right side lower splash shield
      • A/C compressor drive belt
      • Lower alternator cover plate
      • Water pump/alternator drive belt
      • Crankshaft pulley
      • Water pump pulley
      • Timing belt
      • Dipstick tube
      • Upper alternator bracket from the water pump
      • Water pump and discard the gasket
      To install: Fig. 1: To ensure a tight seal, be sure gasket surfaces are properly prepared - Metro 7922z704.gif
    4. Clean the gasket mating surfaces thoroughly.
    5. Install or connect the following:
      • Water pump with new gasket. Torque the bolts to 115 inch lbs. (13 Nm).
      • New rubber seals
      • Upper alternator adjusting bracket
      • Oil dipstick tube
      • Timing belt
      • Water pump and crankshaft pulleys. Leave the water pump pulley bolts hand-tight
      • Alternator drive belt
      • Lower alternator cover plate. Torque the bolts to 89 inch lbs. (10 Nm).
      • A/C compressor drive belt, if equipped
      • Right side lower splash shield.
      • Torque the water pump pulley bolts to 18 ft. lbs. (24 Nm).
    6. Adjust the water pump drive belt tension and torque the alternator adjustment bolt to 17 ft. lbs. (23 Nm).
    7. Install or connect the following:
      • Air cleaner
    8. Refill the cooling system.
    9. Start the engine and check for leaks, repair if necessary.
    Prizm 1.6L ENGINE
    2. Drain the engine coolant.
      • Negative battery cable and properly support the engine
      • Right side engine mount and support
      • Upper and middle timing belt covers
    4. If equipped with power steering remove the following components:
      • Front transmission mount
      • Radiator fan motor
      • Coolant reservoir
      • Upper radiator hose
    5. Remove or disconnect the following:
      • Crankshaft Position (CKP) sensor electrical connector from the dipstick tube
      • Dipstick tube
      • Engine Coolant Temperature (ECT) sending unit
      • Coolant inlet pipe
      • Water pump and discard the O-ring Fig. 2: Remove the coolant inlet pipe from the block, then the pump - Prizm 7922z705.gif
      To install:
    6. Install or connect the following:
      • New O-ring and Water pump. Torque the bolts to 10 ft. lbs. (14 Nm).
      • Coolant hose to the pump
      • Coolant inlet pipe. Torque the fastener to 11 ft. lbs. (15 Nm).
      • Dipstick tube. Torque the bolt to 89 inch lbs. (10 Nm).
      • ECT sending unit to the dipstick tube
      • Engine wire harness. Torque the bolt to 89 inch lbs. (10 Nm).
      • Radiator fan. Torque the bolts to 52 inch lbs. (6 Nm).
      • Coolant reservoir
      • Front transmission mount. Torque the bolt to 47 ft. lbs. (64 Nm).
      • Upper and middle timing belt covers. Torque the bolts to 62 inch lbs. (7 Nm).
      • Right side transmission mount and insulator. Torque the bolt to 47 ft. lbs. (64 Nm).
    7. Fill the cooling system.
    8. Start the vehicle and check for leaks, repair if necessary.
    1.8L ENGINE
      • Drive belt
      To install:
    4. Install or connect the following:
      • New O-ring and water pump. Torque the bolts to 8 ft. lbs. (11 Nm).
      • Drive belt
    5. Fill the cooling system.
    6. Start the vehicle and check for leaks, repair if necessary.
    Jan 02, 2011 | Chevrolet Metro Cars & Trucks
    Change water pump on 1999 Century Buick
    GM Century/Lumina/Grand Prix/Intrigue 1997-2000 Water Pump - REMOVAL & INSTALLATION
    3.1L and 3.4L (VIN E) Engines
    1. Disconnect the negative battery cable.
    2. Partially drain the cooling system into a suitable container.
    3. Remove the drive belt guard.
    4. Loosen the water pump pulley bolts before removing the drive belt. This should help keep the pulley from turning as the bolts are loosened.
    5. Remove the drive belt. Please see .
    6. Remove the water pump pulley bolts and remove the pulley.
    7. Remove the water pump bolts and separate the pump from the engine front cover.
    To install:
    Fig. Exploded view of the water pump and front cover arrangement-3.1L and 3.4L (VIN E) engines
    1. Clean all parts well. Use care when scraping gasket material from the front cover and the pump. Do not gouge aluminum parts. Clean the bolt threads well. The torque specification is low and if the bolt threads are dirty, an accurate torque is not possible and leaks are likely to develop.
    2. Using a new gasket, install the water pump to the front cover. Install the cleaned and lightly lubricated water pump bolts. Torque to 89 inch lbs. (10 Nm).
    3. Install the water pump pulley and bolts and torque to 18 ft. lbs. (25 Nm).
    4. Install the remaining components in the reverse order of the removal process. When refilling the cooling system, use the proper mix of DEX-COOL® and water. Check for leaks.
    3.4L (VIN X) Engine
    3. Remove the coolant recovery reservoir.
    4. Remove the drive belt. Please see .
    5. Remove the pulley bolts and separate the pulley from the water pump.
    6. Remove the water pump bolts and remove the pump from the engine.
    Fig. Exploded view of the water pump mounting-3.4L (VIN X) engine
    To install:
    3. Install the water pump pulley and bolts and finger-tighten the bolts.
    4. Install the drive belt, then torque the pulley bolts to 18 ft. lbs. (25 Nm).
    5. Install the remaining components in the reverse order of the removal process. When refilling the cooling system, use the proper mix of DEX-COOL® and water. Check for leaks.
    Hope this help (remember comment and rated this).
    Apr 04, 2010 | 1998 Buick Century
    Replace water pump 02 sportage
    I'm going to assume you have the 4WD model..here are the instructions for removal and install:
    2. Remove or disconnect the following:
      Negative battery cable Lower splash shield Upper and lower radiator hoses Coolant reservoir tank hose Fresh air duct Fan and shroud Loosen the alternator mounting and adjusting bolts Alternator belt Fan pulley and bracket Upper and lower timing belt covers and turn the crankshaft until No. 1 cylinder is at Top Dead Center (TDC). Loosen the tensioner lockbolt and pry the tensioner away from the belt Timing belt Loosen the tensioner bolt Water pump Tensioners from the water pump
    To Install:
    1. Clean the surface of any old gasket material.
    2. Install or connect the following:
      Tensioners on the water pump Water pump and gasket. Torque the bolts to 19 ft. lbs. 25 Nm). Timing belt Loosen the tensioner lockbolt and allow the tensioner to rest against the belt. Torque the tensioner lockbolt to 32 ft. lbs. (43 Nm). Upper and lower timing belt covers Fan bracket assembly and fan pulley Drive belt Cooling fan and shroud Position the radiator and torque the bracket bolts to 89 inch lbs. (10 Nm). Torque the shroud bolts to 89 inch lbs. (10 Nm) and torque the alternator adjusting and mounting bolts Position the fresh air duct over the radiator and tighten the retaining bolt 89 inch lbs. (10 Nm) Radiator hoses and tighten the clamps Lower splash shield Negative battery cable
    3. Fill the cooling system.
    4. Start the vehicle and bring the engine to operating temperature. Check for leaks and repair if necessary.
    Oct 28, 2009 | 2002 Kia Sportage
    How do you replace a water pump in an aztec?
    Notes Water Pump Replacement
    Removal Procedure
    2. Remove the drive belt guard.
    3. Loosen the water pump pulley bolts.
    1. Remove the water pump pulley bolts.
    2. Remove the water pump pulley.
    1. Remove the water pump bolts.
    2. Remove the water pump.
    3. Remove the water pump gasket.
    4. Clean the water pump mating surfaces
    1. Install the water pump gasket.
    2. Install the water pump. Notice: Refer to Fastener Notice in Service Precautions.
    3. Install the water pump bolts.
    1. Install the water pump pulley. Loosely install the mounting bolts.
    2. Install the drive belt.
      • Tighten the bolts to 25 Nm (18 inch lbs.) .
    1. Install the drive belt guard.
    2. Fill the cooling system.
    3. Inspect the cooling system for leaks
    Jun 17, 2009 | 2001 Pontiac Aztek
    Boating Logo
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
