Question about Samsung HLP4663W 46" Rear Projection HDTV
High frequency noise - Samsung HLP4663W 46" Rear Projection HDTV
  • Samsung Master
  • 8,457 Answers
This tv have a colors wheel.Have loud squiling noises,motor noises,humming noises and pictures flicker black and white.The colors wheel is dead.The colors wheel require changing.Hire a tv Tech. for this job.Changing the colors wheel is difficult,require take out alot of mechanicals,before even can change the colors wheel.
Posted on Sep 11, 2010
  • 63 Answers
Change color wheel part number bp96-00674a order from hbf electronics 215-338-1100 tell em ethan gave you the number i just they have a few more in stock
  • 51 Answers
Hi. The most common cause for this is the color wheel. Replacing it requires removal of the engine/optical block. I'm not sure of your level of expertise but if you want to give it a try go to this website: http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ It'll give you some idea of what you're up against. It is similar to what you'll have to do but I don't think your chassis is exactly the same as this one so some things will look different inside.
I have a Yamaha HTR 6180 reciever and 2 AR 328ps speakers one of the speakers when turned up with shut the reciever down I did a prosses of elemination and took each speaker out of the tower individually...
A capacitor is more like to fail than a coil, so I would also suspect a cap first. Capacitors conduct high frequency more than low frequency, so this may explain the extra load and shutdown on high frequencies.
Jan 21, 2015 | Yamaha Audio Players & Recorders
Subwoofer makes noise like an untuned TV regardless of volume knob
I would suggest your crossover unit has failed in the speaker cabinet. The crossover circuit board separates the low and high frequency content of your stereos audio signal. The low frequencies go to the bass unit (woofer) and the high frequencies go to the tweeter speaker. If the capacitor on the crossover goes open or near open circuit then noise is introduced into the sound system. Replace either the capacitor or crossover unit.
Jan 18, 2014 | Cambridge Audio Minx X300 - Powered...
Realistic pro-62 scanner emits high frequency buzzing noise after half hour or so of being switched on?
There is a problem with something breaking down in power supply side. It could be a filter capacitor or a semiconductor.
Apr 18, 2013 | Radio Communications
High frequency noise from toshiba dvd recorder
if you can remove the cover of your dvd recorder, then access the power supply board first check if their is bulging capacitor or transformer which emits the noise.if ok, observe if the noise is coming from the dvd burner during recording.
Sep 15, 2012 | Toshiba DR410 DVD Recorder
My tv started to hum have figured it to be part of the backlight NEED HELP?
Hello Sir, Hi, if that is the case, your inverter board is generating audible high frequency noise. the inverter board is true to produce high frequency pulse needed by the LCD, but if should not be audible. try replacing the inverter board and see if the noise will dissapper .
Jul 17, 2012 | Insignia NS-LDVD26Q-10A 26 in. HD-Ready...
High Frequency Noise
Most sets if this: it is a transformer on the power board--we usually open and listen to locate this--on occasion we use a microphone and a scope for this.
Cure is either replace the entire board or in some cases if locate to one part use hot glue to mute the noise.
It is being caused by a transformer that is vibrating hard enough to make the sound-part is not bad in usual sense of the word but is not pleasing to hear.
SD TECH
Apr 23, 2012 | LG 52SX4D 52" HDTV
I'm hearing a high frequency electrical "whirring"
COuld be a grounding issue. Place a ground plug on your computer where it plugs into the wall outlet. You can get these at almost any store for about a $1.
Otherwise, you might try using a battery backup system.
Mar 21, 2011 | Sony MDR-7506 Professional Headphones
My monitor is making high frequency noise
Install an AGP card into an AGP slot .because motherboard with internal display card does not support high resolution use 8X AGP card for better result
Mar 31, 2010 | Hansol 730E 17" CRT Monitor
How do i turn off the high pitched frequency noise
If what we are talking about here an old model of monitor that has a bulky back, the high pitched frequency is caused by other electronic devices such as your speakers.
- Relocate your speakers away from the monitor
- do a factory reset on all settings on the monitor or if possible, do a degauss.
Dec 16, 2009 | Computers & Internet
Samsung HLP4663W 46" Rear Projection HDTV Logo
158 people viewed this question
Henry  Thomas
Henry Thomas
