Question about Everest Refrigeration EPR3
The fan working but fezzer and cooler not cool
  • Everest Refr... Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
My double Cooler Master Cooling Fan R4-S4S-10AK-GP that i use underneath my laptop stopped working even though its not been in use for long time i bought it as part of a cooling pad with removable cooling...
If the fan spins and you find there is power going to it, then likely the electronic drive circuit has failed. You can get replacement fans at stores like Fry's and other sources.
Aug 03, 2011 | Cooler Master R4 Series Silent 140mm Case...
I am looking for the cooling fan for a Danby Silhouette DWC512BL-1 wine cooler. A google link took me to your site but I don't see any links to Danby parts.
As I have worked on a few ELECTROLUX wine coolers and they do not have a cooling fan for the inside of the unit are you speaking of the one under and in back of your cooler if so then it is a condenser fan motor it will be 110v and your local appliance store should be able to order one close enough to work in design and rotation of it. Hope this helps.
Apr 09, 2011 | Danby DWC513BLS Wine Cooler
I have a model 5645 and it has stopped cooling
the outside fan can be replaced with a 92 x 25 mm computer cooling fan. Inside fan is a 60 x 10 mm. Remove the cover on the inside by pulling straight up. Plug it in and check if the metal heat sink on the inside is getting cold. If it does, then the problem is one or both of the fans.
Mar 15, 2010 | Coleman Electric Cooler 40 Beverage Cooler
Coleman Electric Cooler doesn't stay cold
the most common problem is that one or both cooling fans has failed. If you have the newer version, you can get replacement fans anywhere computer parts are sold
Jul 03, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Water Cooler Not cool
hi,
Please check the control.
May 06, 2009 | Heating & Cooling
Sunpentown SF-609 Evaporative Air Cooler - no cool air
Sometimes there is a separate switch to turn on the water pump. No water=no cooling. Check to make sure the cooling pads are wet! If they are completely wet and the fan is blowing it should cool.
Jul 06, 2008 | Sunpentown SF-609 Air Cooler Fan
Hamilton beach water cooler is not cooling
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing. A little oil inside the motor and several revolutions later might get some relief until a new motor is installed.
Jun 07, 2008 | Hamilton Beach Water Cooler with Storage...
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Everest Refrigeration EPR3 Logo
79 people viewed this question
Top Everest Refrigeration Refrigerators Experts
mike cooper
Vernon Taylor
ray gallant
Are you an Everest Refrigeration Refrigerator Expert? Answer questions, earn points and help others
