Question about Braun FreeControl 1775 Hair Trimmer
Is the trimmer portion of my Braun 1775 shaver available or replaceable. The cutter/foil is readily available, but the trimmer is dull.
  • 3 Answers
SOURCE: braun 7526 shaver switch
Managed to fix it - actually was a 7680. Only do this if you:
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
Posted on Jan 28, 2008
robotek
  • 1512 Answers
SOURCE: Removing BRAUN 1775 Cutter Block
Hi Miller1292
Braun have great user manuals with good pictorial instructions on how to service your shaver. To get a copy for your shaver, go to this site
Be sure to pick one that is in English:) Thanks for using FixYa, a FixYa rating for my solution would be awesome. Cheers
regards
robotek
Posted on May 08, 2008
SOURCE: braun 360 shaver. How to replace the cutter.
yup, it worked. Just pry it up. I used a heavy duty tweezer.
Posted on Feb 10, 2009
brector3
  • 1625 Answers
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
brector3
  • 1625 Answers
SOURCE: How to reduce Braun 5614 shaver noise? Foil and
If you are experiencing unusual noise, most likely, the swivel frame that the foil and cutter fits onto is broken inside. This causes vibration and excessive noise.
If this is the problem, you will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7030220-swivel-foil-frame-p-810.html
Posted on Jul 17, 2011
Testimonial: "I'll try the suggested solution, thanks"
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
Need braun series 7 blades
The blades come mounted in the screen assembly. You will find this cartridge available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-9000-series-pulsonic-foil-and-cutter-cartridge-p-365.html
Aug 15, 2011 | Braun Series 7 9585 Hair Trimmer
Series 3 - 340, my father wants replacement foil & cutter, where can I order one from please.
Braun makes two distinctly different models, both with called seroes 3-340. You will need the type number as written on the shaver to properly identify the correct foil and cutter for his shaver. Both types are available at shaveroutlet.com. See the two links below. You will need to use the type number of his shaver to select the correct one of these two
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-foil-and-cutter-p-141.html
http://shaveroutlet.com/shaver-replacement-parts/braun-series-3-shaver-foil-and-cutter-head-cassette-32s32b-p-835.html
Jan 11, 2011 | Braun Health & Beauty
Need a new foil for model 5479 Braun electric shaver
This particular Braun shaver was made in both a US and European version. They are similar, but take slightly different cutter blocks and foil screens, sooooooo
If you bought your shaver in the US, then you can get a replacement foil here for around $8.00 or you can find another supplier of your choosing.
http://www.ecrater.com/product.php?pid=4997848
If you bought your shaver in the UK, then a replacement is available on Amazon.com (UK site) for quite a bit more in British pounds.
http://www.amazon.co.uk/Braun-Replacement-Foil-Cutter-System1-2-3/dp/B0000X5HPK
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Braun Health & Beauty
When should you change cutters &/or head?
braun series 5 combi 51S replacement screen foil and cutter block for braun 8985 replacement parts.
Jul 19, 2009 | Braun 360° Complete 8985 Electric Shaver
Where can i take my braun shaver for service? needs a foil/blade replacement
you can buy replacement cutter blocks and foils at walmart...about 50 bucks.
Mar 28, 2009 | Braun 360° Complete 8985 Electric Shaver
Hi Miller1292
regards
robotek
May 07, 2008 | Braun FreeControl 1775 Hair Trimmer
Braun FreeControl 1775 Hair Trimmer Logo
53 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
