Question about Brother Sewing Machines
Brother ls2160 how do i thread the bobbin - Brother Sewing Machines
    Genius:
  • 1,788 Answers
Go to brother-usa.com and download your manual for free
Posted on Sep 12, 2010
I have a brother vx1100 sewing machine and I forgot how to combine the bobin thread with the upper thread to start sewing please help
ono secret
just pull the bobbin thread down the slot in the bobbin holder and under the spring plate
leave about 6 " thread loose and put the bobbin and holder back in the machine
use you hand and turn the machine over a few times and the needle thread will pull the bobbin thread up
or use a bit of scrap material and start a short sew
Jan 15, 2017 | Brother Sewing Machines
Why is my brother sewing machince lower thread tangle
try changing the needle
try a different bobbin
make sure the bobbin is wound correctly and not over wound
make sure the bobbin is turned the right way in the bobbin case
clean under the needle plate and in the bobbin area for lint
make sure the top thread has not come off the thread take up lever
Nov 29, 2012 | Brother Sewing Machines
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
brother sewing machine
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
My bobbin thread keeps bunching
rethread the machine top & bobbin, using every thread guide
make sure the thread has not come off the thread take up lever
here's a link for a manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125_EN_272.PDF
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125i_EN_1628.PDF
Jul 17, 2012 | Brother LS-2125 Mechanical Sewing Machine
Brother XL-5130 Sewing Machine
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Feed the thread thru one of the holes (the hole that will be on top) going from the middle of the bobbin thru to top. pull up about 2 inches, push the bobbin over to start winding and before pressing the foot, hold the 2inch piece sticking up. HOLD TIGHT. after the thread is wound about 25 times, stop winding and snip the 2inch piece level with the top of the bobbin. Finish winding.
Apr 13, 2009 | Brother XL-5130 Mechanical Sewing Machine
Brother xr-65 bobbin problem
insert the bobbin so the thread comes out in the middle a away from you, hold the thread end push the bobbin down with with your finger, and pass the thread securely through the thread cutting groove
Oct 30, 2008 | Brother XR-65t Mechanical Sewing Machine
Need timing instruction for brother SE270d
Your needle thread lock on the bottom of your fabric and your bobbin thread locks on top. If you are getting jamming in the bobbin it is caused by the needle thread. Thread your machine with the presser foot up this will ensure thread going between tension disks.
Oct 14, 2008 | Brother SE-270D Computerized Sewing...
Brother sewing machine ls2125
Don't go directly from the thread spool to the bobbin.
You have to go via the thread quide, (near the end of the head at left side) and under the small roller.
Pass your thread to the bobbin turn your thread 3 turns to the right, clockwise,
then pass the end of the thread, under the coming thread and give it another 3 turns to the right.
For better results, always remove old thread from bobbin before filling it up.
Push the thread winder lever to lock the bobbin.
Start winding slowly. If the thread is loading in the down position,
put your finger under the thread between the bobbin and the the thread quide, untill you see that the thread is feeding evenly.
Jun 14, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother PE 400 D threading bobbin problems
im going to help you as much as i can,,,,try using a bobbin that is already threaded and make sure bobbin is in bobbin case correctly, make sure machine is threaded to instructions in book,,,if this is all done exactly u should not have a problem unless something is jammed
Jan 20, 2008 | Brother Disney PE-400D Computerized Sewing...
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
