Question about Panasonic DMR-E85H DVD Recorder
My Panasonic DMR-E85H DVR won't power up. Had been working fine, about six years old, didn't record my last timed recording, then wouldn't power up. Checked cord and outlet. What usually goes wrong inside the machine and what does a fix cost?
  • 3 more comments
  • jdsouthwell Sep 12, 2010
    $50-70 sounds great, but "similar to the cost of a new one"? This is a $700 unit when new....are we talking about the same thing?
    My DMR-E85H
    My DMR-E85H is a full blown DVR with a big hard drive and recording and playback capabilities, not just a cheap throwaway DVD player. I"m thinking there is probably a fuse link or power transformer inside that may have failed (?). It has been powered through a high end power control/surge protector.
  • jdsouthwell Sep 13, 2010
    This sounds like a reasonable scenario, given the unit's installation. I appreciate the help.
  • jdsouthwell Sep 19, 2010
    Azraelsrl, you were spot on, four capacitors and some labor and my DVR is good to go. Thanks!
  • Panasonic Master
  • 11,800 Answers
In an unit of this age the first thing that fails is the power source (more specifically the filtering capacitors - they start to dry out), especially in a unit like this, with very little space inside for air flow and big consumers that generate a lot of heat.
If when the source has failed nothing else was damaged the fix will be quite simple and easy to do and al the replacement part will cost less than $40. To that you must add the labor - that depends on who is going to do the job.
Posted on Sep 12, 2010
  • 3 more comments
  • cotterpin Oct 28, 2010
    Is it possible to buy replacement capacitors and solder them in myself. If its as simple as that I might be able to handle it. Where could I get replacements and what are the specs?
    Thanks,
    cotterpin
  • Azrael SRL Oct 28, 2010
    Of course you can replace them yourself - just unsolder them, copy the specifications printed on their labels and order identical replacements from a good site like
    http://www.talonix.com/shop/category.asp...
  • KurtKilowatt Jan 02, 2011
    Azraelsrl -
    You are correct! Our DMR-E85H DVR didn't power up at all - most likely a power supply problem. Removing the cover, hard drive, and hard drive caddy revealed the power supply
    board with 2 electrolytic capacitors with crusty, brown deposits on their tops. The capacitors had swollen and the pressure release opened, allowing the electrolyte to evaporate.
    We unsoldered one of the caps and tested it on an LCR Meter - only 122mfd - UGH!
    The second cap was removed and tested - 56mfd - double UGH!!
    It appears that the failed caps, C1260
  • KurtKilowatt Jan 05, 2011
    (apparantly fixya truncates comments, so)
  • mrmultimedia Jan 11, 2011
    I have the same problem with my unit. It won't power up. Hate to toss it and buy a newer one since this one model is highly regarded as one of the best on the market. I will find a panasonic repair shop and see if they can replace the caps for me since I am not an electronic genius.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described the issue seems to be with its circuit board going bad and needs to be replaced. The cost to repair this will be around $50-$70 which is quite similar to a new one. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Sep 12, 2010
    I was talking about a normal DVD Player.
  • Rylee Smith
    Have already told you what is the issue, have you checked it?
New hard drive
I would put in the same hard drive capacity especially on a ten year old machine, because the power supply could affect the capacitors on the motherboard and cause a short. Samsung hard drives work best with Panasonic hdd recorders.
Apr 24, 2014 | Panasonic DMR-E85H DVD Recorder
Hi My Panasonic DMR-E85H Won't let me record to the Hard Drive it is displaying NO REC message on the Display ? Any ideas are most welcome .
it's the same problem with panasonic dmr-e55 recorder ; must we slack them for another one !!! we need help seriously
Jan 13, 2013 | Panasonic DMR-E85H DVD Recorder
I have a Panasonic DVD Video Recorder model DMR-E85H manufactured in 2004. It has worked perfectly for all these years but now won't power up at all. I have checked the only fuse I could find inside...
The power supply board is the problem, one of the most common failure is the 1000uf capacitor "open" located near the power transistor that is heat sinked, value may be higher or lower with one or two caps, the second possibility is the power transistor may be open or shorted.
Jun 24, 2011 | Panasonic DMR-E85H DVD Recorder
Why won't dmr e85h pick up all the digital channels the tv attached to it will? Is it outdated technology? Do you need a digital set top box or completely replace the unit? Anyone...?
You most likely will need a set top box connected to this recorder in order to receive digital channels, Assuming the DVD recorder works besides this detail, you should not need to replace the unit. Only replace it if it DOESN'T work.
The DMR-E85H is a 2005 model so it is more than 5 years old.
Mar 13, 2011 | Panasonic DMR-E85H DVD Recorder
"Please wait" ... panasonic dmr-e85h seems frozen
Have you tried unplugging it for a couple of minutes?
Aug 25, 2009 | Panasonic DMR-E85H DVD Recorder
Unable to boot up dvr, stops with at error U99
Panasonic has a web site below where you can download drivers to a disc that can be used to update your dvr. It also has
the operationg instructions on PDF that you can download & print.
Hope this is helpful
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Operating-Instructions/model.DMR-E85HS.O#ts
May 22, 2009 | Panasonic DMR-E85H DVD Recorder
PANASONIC DVD RECORDER DMR-E85HP
Check caps on P/S C1270 and C1271 if puffy replace with {2} 1000uf 35vdc and you should be fine.
Jan 12, 2009 | Panasonic DMR-E85H DVD Recorder
Cannot get E85H to boot - U99 error
I downloaded and installed the firmware upgrade from 2005 (my machine was bought in 04) - after that it is now working fine!
Dec 15, 2008 | Panasonic DMR-E85H DVD Recorder
Connect panasonic dvr through converter box
dear sir i have panasonics dmr-e85h dvd recorder .
so i connect to emerson evc 1595 pal to ntsc to pal video convertor.and i convertor to pal video to ntsc video. but it colity is very bed. and picture is fickaring. so u solve my problems emidently.and some time dvdr- is not supprot to display.
Nov 25, 2008 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
2,065 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
