How to replace computer sound card? - Computers & Internet
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Disable the present onboard sound card in the BIOS. Now insert the new card in the PCI Slot and then switch it on. In windows when it asks the driver provide the cd driver location.
Posted on Sep 11, 2010
Windows Media Player cannot play the file because there is a problem with your sound device. There may not be a sound device installed on your computer
This is an older 16-BIT ISA interfaced Sound Card. Try this one as a replacement.
Sound Card
This will function as a cheap replacement that should run in your system.
Aug 27, 2011 | IBM (01K2154) Sound Card
Can you replace a sound card on a toshiba laptop w/o replacing the motherboard?
No. The sound adapter is integrated into the motherboard, in order to keep the size of the computer as small as possible.
Sep 27, 2010 | Toshiba (4CH-VOUT) Sound Card
My computer has no sound..i think it is not installed..i don't know how to fix it
  1. Step 1 Shut down the computer.
  2. Step 2 Unplug machine from the surge protector.
  3. Step 3 Disconnect all peripherals from the computer.
  4. Step 4 Remove the cover of the chassis and lay computer on its side if it is a tower.
  5. Step 5 Ground yourself to the computer. If you have a grounding strap, put it on and follow its directions. Otherwise, ground yourself by touching a metal part of the chassis.
  6. Step 6 Remove the back panel, if necessary.
  7. Step 7 Locate the existing sound card if there is one already installed. If it is screwed in on the side of the slot hole, unscrew it and pull the card out firmly.
  8. Step 8 If the computer doesn't already have a sound card, find an open slot.
  9. Step 9 Knock out or unscrew the metal plate on the card's slot holder on the back panel.
  10. Step 10 Insert the sound card gently but firmly into the slot. Rock it into position if necessary, but don't force it. Don't touch any connectors on the card.
  11. Step 11 Connect cables from the CD-ROM drive to the sound card.
  12. Step 12 Replace the back panel and any removed screws. Screw sound card into slot holder if it has a screw hole.
  13. Step 13 Reconnect monitor, keyboard, and mouse. Connect speakers to the sound card's ports.
  14. Step 14 Turn on the speakers and restart the computer.
  15. Step 15 If Windows detects the sound card upon startup, follow instructions to install the card's driver and additional software. If Windows doesn't detect sound card, manually complete the installation using the Add New Hardware control panel.
  16. Step 16 Play music CD to test sound card.
  17. Step 17 Shut down computer.
  18. Step 18 Replace cover of computer. Reboot computer.
Aug 16, 2010 | Computers & Internet
How to installsound card
Assuming this is a store bought card...
Put the card into one of your computer's PCI slots
Install the driver your product came with
or
Go online to the manufacturer's website and find the driver there!
Apr 10, 2010 | Computers & Internet
Sound card cannot be detected
  • you remove sound card from the computer.
  • And again Insert in other slot.
Check the computer hope it will work. then no sound card detected. Replace the sound card or have a local tech take a look at the sound card.
Mar 12, 2010 | Computers & Internet
A distorted sound is coming from my speakers even if i connect speakers
It is a possibility that you are getting feedback from a device that is near by. Possibly a cell phone or other device. I would recommend moving the computer to a different location and removing all electronic devices from beside the computer, then reconnecting speakers.
It is also possible that you have a bad sound card. If that is the case, you will need to purchase another sound card and replace the old one. I have included instructions on how to replace your sound card below:
Here is a site where you can purchase the sound card you may be in need of:
http://www.meritline.com/laptop-sound-card-usb-port---p-39078.aspx?source=nextaghdac
There are other sites such as Ebay where you can also purchase the sound card. The type of sound card you need is a PCMCIA Sound Card for an Acer Laptop.
Here are instructions on how to install a new sound card:
    Installing a PCMCIA Sound Card in Your Acer Laptop
  1. Step 1 Locate the PCMCIA card slot on your computer. On an Acer laptop, the slot may be either on the left or the right side of the laptop.
  2. Step 2 Remove the PCMCIA card cover by pressing the "Eject" button and pulling the cover out.
  3. Step 3 Insert your PCMCIA sound card with the connectors facing in and the upper label facing up. Some PCMCIA cards will have an arrow to make it easier to orient the card correctly.
  4. Step 4 Press the PCMCIA card gently into place.
  5. Step 5 Windows will recognize the PCMCIA card and search for the needed software.
  6. Step 6 If your sound card came with an installation CD, insert it in the CD slot and follow the instructions to install applications and utilities for use with your new sound card.
    Installing a USB Sound Card in Your Acer Laptop
  7. Step 1 Turn the computer on.
  8. Step 2 Plug the USB sound card into the appropriate USB plug on your laptop.
  9. Step 3 Wait for the computer to recognize the new USB device.
  10. Step 4 Insert the sound card manufacturer's CD if prompted to do so.
If a sound card is not the issue, then you possibly have circuitry issues on your laptop motherboard. For this issue, you may need to consult a certified technician at your local computer repair shop.
(If you are not a professional or are used to opening your laptop, I would recommend taking it to a local computer repair shop for a certified technician to look at this issue. Do bare in mind if you have a warranty, opening your laptop and not being a certified professional would void any warranty agreement you have with your manufacturer)
Jan 08, 2010 | Acer Aspire 3000 Notebook
Computer does no recognise any sound card/ i just
Visit the sound card manufacturer's site to download the latest drivers for it, or try Windows Update from the Start menu.
Aug 01, 2009 | Computers & Internet
Voice changed
Replace your speakers if they are external by plugging in some headphones or something. If this does not resolve the issue look to the sound card in the computer.
Download and reinstall all sound card drivers for your computer/sound card. If this does not fix the issue, look to replacing the sound card.
Jun 17, 2009 | Compaq Audio Players & Recorders
I was about to install a PCI sound card TM P1018 in my cpu. How will i do it?
Shut down the computer. Unplug machine Disconnect all peripherals from the computer. Remove the cover of the chassis and lay computer on its side if it is a tower. Remove the back panel, if necessary. Locate the existing sound card if there is one already installed. If it is screwed in on the side of the slot hole, unscrew it and pull the card out firmly. 8If the computer doesn't already have a sound card, find an open slot. 9Knock out or unscrew the metal plate on the card's slot holder on the back panel. Step10Insert the sound card gently but firmly into the slot. Rock it into position if necessary, but don't force it. Don't touch any connectors on the card. Step11Connect cables from the CD-ROM drive to the sound card. Step12Replace the back panel and any removed screws. Screw sound card into slot holder if it has a screw hole. Step13Reconnect monitor, keyboard, and mouse. Connect speakers to the sound card's ports. Step14Turn on the speakers and restart the computer. Step15If Windows detects the sound card upon startup, follow instructions to install the card's driver and additional software. If Windows doesn't detect sound card, manually complete the installation using the Add New Hardware control panel. Step16Play music CD to test sound card. Step17Shut down computer. Step18Replace cover of computer. Reboot computer.
Apr 24, 2009 | Computers & Internet
Need to replace sound card for Sony vgn-t350p
It's true that with a laptop, replacing some parts means replacing the motherboard as they are integrated parts, this applies with the sound card. If your laptop is under warranty then you should be able to get it fixed, otherwise you need to weight the cost of replacing the motherboard verses buying a new computer. Seeing as how the motherboard in a laptop is pretty much half the computer, it may be cheaper to buy a new one.
Mar 12, 2009 | Sony VGN-T350/L PC Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
