Question about Sony KP-65WS500 65" Rear Projection Television
Red and green color separation mostly on the left side
  • Sony Master
  • 8,457 Answers
The tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment,have colors shadows picture or 3D pictures.The tv convergencce board require changing 2 STK convergence ICS and some or all it resistors are dead.These parts nust require changing to solved convergence problems.The shop,will cost $300-350 for parts and labors.
Posted on Sep 11, 2010
Color convergence left side of TV
bad convergence ic's. STK392-110. I would suggest using STK392-120. Be sure and use a lot of heat sink compound.
Nov 12, 2011 | Hitachi 51SWX20B 51" Rear Projection...
What are the color codes for a factory stereo system in a 2006 Nissan alttima
use at your own risk. I can not confirm these.
+12V DC Battery(Constant) Yellow/green 31 15 Amp Fuse box on left front of engine compartment, near battery. Switched Accessory Purple 6 10 Amp Fuse block behind left side of dash Power Antenna NCA Green for antenna signal Illumination Red/yellow & red/blue Steering Wheel Control Wire Red/white, green, and blue If equipped, as for Mid-Line. Left Front + Blue/white Left Front - Blue/red Right Front + White/black Right Front - Blue/black Left Rear + Green/yellow Left Rear - Black/yellow Right Rear + Blue Right Rear - Red
titleicon.gif AT SPEAKERS
Wire Function Color Note Left Front Tweeter + Blue/white Left Front Tweeter - Blue/red Right Front Tweeter + White/black Right Front Tweeter - Blue/black
Feb 20, 2011 | 2006 Nissan Altima
Which is the separation wire for the left and right speaker for Kenwood HDC222?
Function Typical Wire Colors Constant 12V(+) Yellow Ignition Switch Red Ground Black Illumination Orange/White Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Purple Right Rear (-) Purple/Black
Feb 16, 2011 | Kenwood Car Audio & Video
No sound on tv and black & white
The red, blue, and green are the component cable hookups. What you have w/ red, white, and yellow is called composite or on most TV's (AV) See if the TV has a side port for like a camcorder, etc. It will not work by hooking into the red/blue/green as they are different signals.
It is possible that your yellow jack may be separate from the red/white audio left/right jacks.
May 04, 2010 | Sony PlayStation 2 (PS2) Console
Colors of the wires for CX 400 headphones
yellow and red-green are most likely grounds. red is normally the right channel and green is normally the left channel. quick question though, why on earth would you cut the plug off of a pair of 75-90$ headphones?
Apr 15, 2010 | Sennheiser CX 400 Headphones
Not real colors. maybe no green color
Projection TVs display using three separate color tubes red, green, blue. The less likely scenario is the tubes being out of alignment. Most likely scenario: the green tube is leaking/failing.
Unfortunately, there are many complaints regarding a color tube giving out on these types of TVs.
You should be able to search the internet for instructions on replacing the color tubes.
Sep 04, 2009 | Televison & Video
2 separate colors on screen
sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2008 | Sony KP-53V75 53" Rear Projection...
Sony 65 Inch Projection TV Color Red Green Separation
Sounds like a convergence issue. Call Sony for an ASC that can come out and give you an estimate. You are probably looking at $200-400 to do the repair.
Nov 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Sony KP-65WS500 65" Rear Projection Television Logo
307 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
